truck wont start on first try
Old Jan 16, 2008 | 08:54 PM
heykw's Avatar
My 01 won’t turn over. When I hit the key the first time it just clicks, like it's got a bad battery after hitting the key several times it will fire right up. Help? I almost got strained this evening it took like 10 tries to get it to turn the motor over. I think it is the starter.
Old Jan 16, 2008 | 09:57 PM
J Lent's Avatar
Starter contacts are bad.
Old Jan 16, 2008 | 10:09 PM
b4wheeler's Avatar
Buy a starter rebuild kit off Ebay and rebuild it now, before it doesn't start at the wrong time and you lose a day of work because you are rebuilding your starter.
The kits are ~$20 and it takes about an hour from start to finish.
You will need a 12pt 10mm box-end wrench to get to one of the starter bolts. You can get to the rest with a regular socket.
Old Jan 16, 2008 | 11:02 PM
thewished's Avatar
Check your power wire running to your starter from your battery, that was one problem with mine, the other was the wire running between my batteries would let power over to the other one then stop for a bit. Hope you get to the bottom of it
Old Jan 17, 2008 | 07:18 AM
heykw's Avatar
Got a link to the starter rebuild kit and contacts
hemimaniac
Nov 17, 2014 09:52 PM
93-12Smoke
Mar 24, 2010 05:30 PM
jmccart
May 28, 2008 08:51 PM
qcstunter
Jan 9, 2007 04:10 PM
Journier
Feb 4, 2005 11:02 AM
