pop when turning left
Old Nov 17, 2014 | 11:13 AM
marder's Avatar
I'm hearing a single pop or knock sound coming from the passenger side rear when I make a left turn. I dont see anything unusual underneath. Anyone know if this is a symptom of something? Does it in reverse too.
Old Nov 18, 2014 | 03:39 AM
Steve-l's Avatar
I suspect, that you have a bad axle U Joint. U Joint failure is a common reoccurrence with these trucks. I keep replacements for the drive line and front axle on the shelf. It is that common. Changing them out is a 2 hour job per side, if you have the right tools. Be sure to replace the originals with quality replacements that have grease fittings and have a tub of anti-seize grease handy, you will need it!
dieselJon
Nov 21, 2007 05:53 PM
973604x4
Sep 4, 2007 08:18 PM
Turbo Deeezle
Feb 21, 2005 12:24 PM
BigBlue
Oct 14, 2004 11:21 PM
MK4288
May 13, 2004 12:16 AM
