03 (stock) wont start and threw p0602
Ok please dont tell me I have to replace the ECM! Made a 45 mile quick trip. Shut down the rig and tried to start again 20 min later. Crank but not starting. I tried allowing the electronic fuel pump to cycle for about 30 sec several times and still not getting fuel. Threw the P0602 code. Should I try the battery disconnect reset?
that is what the code is showing a programmer not programmed right yes try to disconnect the batteries and let it sit for awhile to clear itself also check the map sensor mine did this and the map sensor was corroded really bad cleaned it and dielectric grease in it and it is good to go now just my 02.
CACalomino
05-31-2009 01:35 AM
fredw
14
01-16-2006 11:43 PM
