03 Spitting Coolant
Old Jul 22, 2006 | 09:59 AM
Dinner's Avatar
03 Spitting Coolant
A buddies freind of mine has an 03 2500, 90K, K&N Filter and thats it. The other day his dad notice that there was coolant on the ground so he opened the hood and there was coolant all over the hood. He says when it is cool it will leak the coolant, but once warmed up it doesn't anymore. And the bearing(s) in the water pump are gone as well. So what could be causing this?
Thanks, Dinner
Old Jul 22, 2006 | 12:18 PM
Dodgezilla's Avatar
If you look at the overflow tube on the passenger top side of the radiator, you will see that there is no bandclamp holding the hose on. Many of us had a coolant leak there, and the fix was just putting a hoseclamp on it. Try that.
Old Jul 22, 2006 | 01:48 PM
03 ant a hemi's Avatar
Check the plugs that are at the top of the engine next to the valve cover. Mine were all loose and I was loosing coolant from there.
astickerlady
Nov 3, 2007 11:56 AM
mhuppertz
Aug 4, 2007 06:57 PM
NoSparkplugs
Oct 24, 2005 10:15 PM
SmokinFive9 4x4
Oct 27, 2004 10:05 PM
KATOOM
Apr 17, 2004 10:05 AM
