03 rail pressure PLEASE HELP!!!
Old Jul 30, 2007 | 12:30 PM
vzdude's Avatar
DTR's 'Go to Guy'
The white with orange tracer wire should be the vehicle speed sensor wire. If we are talking about the same plug on the ecm. 2 plugs that have a bolt in the middle of them?
Old Jul 30, 2007 | 12:48 PM
hallsbobcat's Avatar
I Believe the # is 11 on the plug, were the white and orange wire go's in at.
Old Jul 30, 2007 | 05:42 PM
carleshicks's Avatar
souns like a whole bunch of culprits can cause this I hear a clicking sound when my key is on until the truck starts. is this the fca or the relief vvalve.
Old Jul 30, 2007 | 06:19 PM
vzdude's Avatar
DTR's 'Go to Guy'
Yup ! #11 is the speed sensor signal wire.
Old Jul 30, 2007 | 06:21 PM
53 willys's Avatar
do you have any codes???
Old Jul 30, 2007 | 06:34 PM
rams-n-hogs's Avatar
Sounds like it could be an injector, or the relief valve. If the CP3 can't build pressure, the truck won't start.
Old Jul 30, 2007 | 07:21 PM
I just went out and took the fuel filter out and put it back in I let it run through two prime cycles and it started right up. Now that makes no sense to me. By tomorrow after a few starts and stops it will not start again that has been the way it has been going for about 4 weeks now. It does not have any codes and none of the fuel line are leaking. I am going to take it to the dealer this week. My buddie is a mechanic at the Dodge dealer ship and if I tell him what I think is wrong he won't waste a bunch of time checking other things so I am glad for any advice.
Old Jul 31, 2007 | 04:47 AM
CTD03's Avatar
injector or injectors
flow test
this is comin problem
Old Jul 31, 2007 | 05:51 AM
dogger's Avatar
Just a couple of thoughts
How many miles do you have since you last changed your fuel filter?
This is probably not the case but some diesels once the get "hooked" on ether to start they have a heck of a time starting without a "fix".
L8r,.............dogger
Old Jul 31, 2007 | 03:18 PM
THis fuel filter mabey has 500 miles on it I have put 4 in during the last month
Old Aug 1, 2007 | 06:51 PM
cwoodall's Avatar
I sure hope you find out what it is.....I have the same problem
Old Aug 1, 2007 | 11:47 PM
I have an appointment at the dealer nest wednsday I will keep you all posted
5.9Excursion
Mar 13, 2008 10:56 AM
SuperiorRam
Mar 15, 2007 03:10 AM
subspd
Dec 24, 2006 02:01 PM
rjm022
Dec 14, 2006 05:20 AM
mtl0727
Nov 5, 2005 06:47 PM
