03 No start
Old May 21, 2012 | 09:30 AM
brentbiely's Avatar
Yes, I may be learning this the hard way. I had no idea CR engines were so intolerant of dirt and grit. Also in the dark about the cost of replacing injectors. Thanks for the other info, though, as I may need to install additional filtering on the truck.
Old May 29, 2012 | 09:55 PM
brentbiely's Avatar
So I've got two of the Miller 9011 caps for the fuel rail and I've tried capping each injector in turn but still no luck - not starting. A shot of ether will get the engine to run for maybe one or two seconds but thats it. I'm sure I'm getting fuel to the rail. Hard to believe that more than one injector has gone bad at once.
Should I do a return flow test while cranking at this point? Any other ideas would be helpful.
Old May 30, 2012 | 05:54 PM
DodgeRam24V's Avatar
Originally Posted by DodgeRam24V
i opted to remove the injectors and have them bench tested and get straight to the point, which it was.
when my truck wouldn't start, this is what i did second ^^^, FAC first, this saved me a bunch of time, not money.
I still say if your common rail will not start, pulling the injectors and having them checked is good information.
CoolumConst
Oct 11, 2008 10:00 PM
bfarrell
Nov 30, 2005 03:23 PM
Erik Dlux
24
Dec 8, 2004 07:26 AM
502502
Nov 27, 2004 09:15 PM
eng208
Jul 14, 2004 06:21 PM
