03 Fuel Pressure
Old Oct 11, 2003 | 08:39 AM
silver_goat's Avatar
03 Fuel Pressure
Where is the best place to check the fuel pressure on an 03. The 02's had a srader valve on the VP44 I could use manual gauge to check. I do not see anything like that on the 03.
Old Oct 11, 2003 | 06:56 PM
Re:03 Fuel Pressure
no takers on this one? ???
Oh well :'(
Old Oct 11, 2003 | 07:23 PM
Scubasteve's Avatar
Re:03 Fuel Pressure
If no one will chime in on this I will offer my opinion atleast. Seeing as the lift pump is bolted directly to the fuel filter housing I would tap into the fuel feed from the bottom of the filter housing and put your guage there, it may already have a shrader valve on it..
Good Luck
Jason
Old Oct 12, 2003 | 11:56 AM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
Re:03 Fuel Pressure
On the 03's you have to use a tapped banjo or other tapped fitting on the injection pump. The bottom of the filter canister has changed, and they've stuffed a brace in the way that makes it nearly impossible to get anything onto a tapped fitting.
Rod
Old Oct 12, 2003 | 08:00 PM
Scubasteve's Avatar
Re:03 Fuel Pressure
thanks Rod, I wasn't sure so I took a crack at it but am glad you cleared it up
Jason
Old Oct 13, 2003 | 03:39 PM
Re:03 Fuel Pressure
Thanks Rod!
I was afraid that was the case. So tapped banjo bolts are the only way to go. Where is the best place to add the tapped bolt?
Old Oct 15, 2003 | 11:56 AM
Agades's Avatar
Re:03 Fuel Pressure
Rod,
do u have these banjos for sale ?
They look smaller than the 2nd gens . r they?
(the only other place I ever got gold stars was kindergarden)
dodgeguy71
17
Jan 19, 2012 12:52 AM
bigragu
Jan 24, 2006 11:16 AM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
