03 auto (48RE) won't lockup or go into 4th
I just noticed this today while running some errands... the transmission won't lockup or go into fourth gear. The only thing I can think of is maybe it's related to the colder weather, which has been in the -5 to +5 range. I know it isn't supposed to do either until the trans fluid hits 120 deg, but I had been running quite a few errands, and I really don't see why it wouldn't be that warm by that time.
Any thoughts in case fluid temp isn't the problem? I checked the level and it appears fine (if bubbly), and in fact I changed the fluid and filter back in August and it's been working just fine since then.
Thanks!
Rob
Thanks!
Rob
Thanks!
Rob
Thanks!
Rob
Jamie
My 03 just did the "not shift to 4th or OD" trick this last week. The dealer kept it telling me he thought it was a sensor. It's been in colder wx and hasn't done that. Drove it for 10 miles or better in 3rd. Drove it for two days checking. Should've warmed up. Temp outside in the mid 30's. I'll find out first of week what they want to tell me about the xmission, but in the mean time, they ripped the right rear quarter panel out of it. Hit a bollard, concrete post that holds up their drive through. That'll set em back. I'm driving one of their new Hemi's. Zippy little thing. Waiting to hear what you find out.
I'm glad it's not just my truck... because it's still doing it.
I tend to think it's a sensor too. There are times when it'll work okay, such as if I have it plugged in for a few hours, but otherwise, it pretty much doesn't anymore. It doesn't seem to get warm enough driving around town (low-speed stop and go), even for 30-40 minutes, to make it warm up enough to lock up or shift. It's really annoying.
I have just under 41k miles on it... should still be under warranty, as they tell me my powertrain is good til 70k and the motor of course til 100k.
Rob
Rob
I was just going to comment. Mine was also the wiring harness. They're changing it and also the clock spring in the steering wheel. Not related to the upshift failure, but TSB on it evidently. Effects cruise control. Ain't life grand. They've still got to replace the bed from them tearing the side out of the truck. I'm thinking hard about leaving it with them and let them worry about it while I drive off the lot with one of their new ones they haven't broken.
upshift
I drive these cummins for demo's and when it's really cold (below 0 F) I can drive the 25 miles to work at road speeds without getting into OD must be the tranny cooler working too well.
I don't think that's normal. Too many instances of wiring harness changes making it different. I had mine changed and it hasn't done it since. Shifts into OD in approximately a mile...... first time I can get to that speed because of streets. Haven't had zero since changed, but it was also doing it at temps as high as 20.
Thanks!
Rob
Thanks!
Rob
Angry Johnny
Aug 23, 2016 05:01 PM
caleb
Nov 1, 2009 07:50 PM
#2 only
Sep 7, 2008 07:42 PM
