`04 or `04.5
`04 or `04.5
FIRST POST!
Bought a `04 to tow my crawler around about a week ago-this is my first Dodge, my first diesel . Power is awesome, can`t wait to toss an exhaust and intake on it....
which brings my to.....How can I ID my truck as an `04 or an `04.5???
I heard of there is a 305 or 325 sticker or casting under the black plastic "valve cover"...I didn`t see sheat! Where is this found? My truck still has the OEM exhaust, I also heard that `04.5`s have a 4" mandel bent downpipe and a cat too...
Looking at MBPR`s 5" turbo back, aFe`s stage II, and a smarty....
Thanks for yer help.
welcome to dtr
look under the truck. do you see a catalytic converter before the muffler? no=04, yes=04.5
drivers side front of the motor. on the side of the timing cover(not valve cover) there is a white and black sticker.
Administrator/Jarhead
04.5 = 325 HP 610 ft lbs tq. (on sticker under valve cover) Made after Jan 04 = 04.5. Check the manufactures sticker inside the driver side door jam. 04.5's had the electronic wastegate also. Yes, they do have the 4" down pipe. The smarty is a good choice from what I have heard, I'm biased to the edge juice with attitude myself. Save your $ on the exaust, just buy a muffler delete pipe and run a straight pipe. It's loud, tho...
Welcome to the DTR... Fill out your sig as soon as you figure out what you have. Go to the top left part of the page, click on user CP, then edit signature.
Thanks Yal!
This confirms that I have an `04.5.
Parts will be ordered tomorrow.....
I've wondered about that. I asked the mechanic at the dealer and he said that there was no difference. They simply upped the #s for the tq/hp wars.
I have no way of knowing if this is true or not though.
Joe
Joe
Here is a break down of the motors and trannys based on year:
2003 S.O. Federal Emissions: 250HP/460lb.ft. Available with NV4500 or 47RE
2003 S.O. Calif. Emissions: 235HP/460lb.ft. Available with NV4500 or 47RE
2003 H.O. Federal Emissions: 305HP/555lb.ft. Only available with NV5600
2003.5 The 47RE was replaced by the 48RE automatic transmission and available with the H.O.
2004 S.O. Calif. Emissions: 235HP/460lb.ft. Available with NV4500 or 48RE
2004 H.O. Federal Emissions: 305HP/555lb.ft. Available with either NV5600 or 48RE
2004.5 (50 state legal) 325HP/600lb.ft. Available with either the 48RE or NV5600
2005 (50 state legal) 325HP/610lb.ft. Available with either the 48RE or NV5600
2005.5 The NV5600 replaced with the G56 6spd manual gearbox.
Hmmmm.... I'm gonna have to go look at my sticker... Coulda swore I saw 610. I'm not saying that I've never been wrong, before, either. (maybe that's just what I wanted... )
i didnt want to call out mark on his little mistake........ the 04.5's were 600ft, but when you took them in for reflashes for the white smoke, etc. you got the 610ft program(or so i was told). either way, 600ftlbs isnt enough!
Maybe that's what I was thinkin! I did get the reflash... Hey, DZ, don't worry about hurting my feelings... I ain't got none...
Besides... my truck ain't seen 610 in a few weeks...
What year do I upgrade to?
I think I'm ready to get a newer truck. I like my 01. It's pretty fast with the auto tranny but driving my dads 01 manual is a lot more fun. I could use the room from a real full four door. I want a white shortbed 6 speed. From the specs above it seems like the 04s to 05s are what I should look for. From 03-06 what are some opinions on the best year and manual tranny? Do any of them have problems I should watch out for? Thanks
