***p0192***
Old Oct 14, 2008 | 05:18 PM
solostyle1's Avatar
***p0192***
keeps throwing this code. any ideas why?
Old Oct 14, 2008 | 05:43 PM
JP-4.5's Avatar
What do you have for CP3 and lift pump feeding the fuel to CP3?
Old Oct 14, 2008 | 06:31 PM
solostyle1's Avatar
stock cp3 and a Airdog 150
Old Oct 14, 2008 | 06:52 PM
JP-4.5's Avatar
I was thinking either your CP3 or lift pump were possibly bad... I am not sure how a CP3 can be tested? Could you CP3 of been damaged when your lift pump failed? From other posts you have had it seems like you have been chasing a fuel issue for awhile...
How does the truck run? Any problems with power or how it runs?
Anyone know how to test a CP3? Is this code a sign of CP3 failing/Failed?
Old Oct 14, 2008 | 07:27 PM
CTDinMT's Avatar
Check your connections for your Edge and put a little dielectric grease on them. Then you'll have to take a code reader and clear the code.
Nevermind! Reading wrong truck info. Have you tried clearing the code? Also, check the connection on your rail press sensor.
Old Oct 14, 2008 | 08:23 PM
solostyle1's Avatar
the truck is running great besides this problem. the lift pump never failed....i was told it was bad from dodge and it turned out that they were full of shiz! Im gonna try and clean all the connections tomorrow. where do you get the dielectric grease?
Old Oct 14, 2008 | 08:38 PM
CTDinMT's Avatar
Any auto parts place will have dielectric grease. Your lucky the trucks running good. P0192 always throws my truck into limp-mode until I clear it.
Old Oct 15, 2008 | 04:34 PM
solostyle1's Avatar
well...its not working and now its bad. running like crap and making a knocking sound. i cleaned it all up. I cant get the BD to clear the codes. i started the truck and the main fuel line on top of the relief valve was extremely hot! with the truck running only a few seconds......
Dieselhed
Dec 29, 2007 07:11 PM
CTDinMT
Jun 21, 2007 12:21 PM
H8GAS
22
Feb 15, 2007 09:40 AM
coobie
Oct 17, 2005 10:53 AM
schorb
Oct 9, 2005 10:59 AM
