Engines apart ..................
Old Oct 14, 2008 | 08:03 PM
TriSum's Avatar
Well, as it says. The engine is apart, new short block is going in. Any things I should have done while it's out ??
I'm doing the obvious, water pump, hoses, thermostat, ARP studs, cam and springs.
What else ????
David
Old Oct 14, 2008 | 08:23 PM
06RAM2500's Avatar
Take a look at the starter, change out the front seal on the transmission.
Old Oct 15, 2008 | 03:08 AM
dozer12216's Avatar
Does radiator need cleaning at this time???
Clean and detail the engine compartment so it will sparkle with new engine in.
Repair any damaged wiring and insulation. Clean all grounds as can get to them.
Old Oct 15, 2008 | 06:50 AM
levigarrett76's Avatar
whats the best method of cleaning the radiator when its out...spray it from the engine side with some degreaser then spray it out with a hose?
Old Oct 15, 2008 | 05:10 PM
dozer12216's Avatar
I was thinking of internal cleaning. Let some engine cleaner set and rinse. May have to do several times is gooped up. Mine was so bad had a radiator shop clean the outside.
Old Oct 15, 2008 | 06:25 PM
D45's Avatar
D45
Take it to a radiator shop and have it steam cleaned and degreased.
Typically costs $50
cbx
May 18, 2009 07:23 PM
thumper 549
Sep 8, 2003 05:03 PM
Bart Timothy
Mar 17, 2003 06:08 PM
James Andres
Jan 20, 2003 09:02 AM
