Code
Old Jun 6, 2012 | 07:27 AM
chamisi's Avatar
Code
Here's the issue the truck threw a code lost power then came back, was able to drive home ran it by the parts store scanner said TPS, I didn't get the actual code from the parts guy so was going to go back and have it scanned again. Now the check engine light is NOT on ? is do I need to look for a bare wire or something?
Old Jun 6, 2012 | 07:53 AM
jhenson's Avatar
Try the key trick to display any codes in your odometer window. That code will really help the folks here narrow down your problem. Our trucks do not have a TPS (throttle position sensor). We have an APPS (accelerator pedal position sensor) which can be located either on the drivers side of the block up by the valve cover under a black plastic boxy thing or under the drivers side battery. Most of the symptoms of a bad APPS will be a "dead pedal" so to speak.....give it throttle and no go.
coope3
Feb 21, 2009 04:49 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
bkay
Mar 25, 2003 10:41 AM
