06 dodge ram
Old 01-31-2015, 08:02 AM
matdieseltech's Avatar
06 dodge ram
need little help i dont like the sound need some others opinion runs great no smoke no blow-by bully dog programer only does it at idle and engine is warm
Old 01-31-2015, 10:11 AM
ssteve58's Avatar
Sounds pretty normal to me, but thats just my opinion. You probably could put a gas motor in it and the noise would go away.
Old 01-31-2015, 11:01 AM
EDR
EDR's Avatar
I heard a slight change in tone at one point, but it sounds normal to me as well.
What exactly are you hearing that has you concerned?
You may want to add your trucks' model year and any mods installed. It may give everyone a better idea as to what, if anything, is going on.
Old 01-31-2015, 12:41 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
Sounds loudest in front, did you try removing serp belt to make sure it's not a fan hub bearing or belt tensioner noise? Also do you have a vac pump for exhaust brake installed? Sometimes those vac pumps will make a hell of a noise when going bad.
Old 01-31-2015, 05:10 PM
Danderson's Avatar
I don't have the tick tick sound. Aside from that,mine's the same.
Old 01-31-2015, 05:27 PM
rockcrawler304's Avatar
Sounds pretty normal to me too. But diagnosing odd noises in the engine compartment on these is very hard to do with a video because there is so much other noise that gets picked up.
I did hear a different tone or even knocking type sound when you went to the front but still hard to tell.
Old 01-31-2015, 08:01 PM
i was little worried about the sound you here in the front realize common rail engine sound different bought the truck with 50% over injectors has s&b intake with ram air bully dog tuner with boost fooler built transmission engine runs good no blow-by does not smoke starts very easy just little noisier my opinion never been around any common rails thanks for all the help
Old 01-31-2015, 08:57 PM
Take the Bully Dog off and see how it sounds.
Old 02-01-2015, 09:10 AM
will try that thinking about getting efi live
Old 02-05-2015, 07:33 PM
banyon's Avatar
It doesn't sound right to me. Maybe a rocker loose?
Old 02-05-2015, 09:41 PM
Cummins Guru
BigIron70's Avatar
Sounds like a FCA problem or CP3 pump phasing is incorrect.
Old 02-11-2015, 02:40 PM
Al Ex's Avatar
Mine has sounded that way since the day I bought it new in '06. To me it's always been a little more clanky sounding than some others. But like I say, my '06 sounds exactly like what I hear in your post and it's been doing it for the 140K that's on it. Never had one problem with it - burns 0 oil, and the only blowby I get is stomping on it. At 65K I added a Smarty Jr set at full POD, and that adds slightly more smoke than stock, but understandably so.
Old 02-13-2015, 01:29 PM
thendric18's Avatar
Doesn't sound like my 06. When you rev it in neutral (2000 RPM) and let off the throttle does it idle smoothly back down to normal idle speed? Or does it seem to "step" down to normal idle speed? To me it sounds like injector noise. Does it ever take long to crank over and start?
My injectors were leaking and I had no smoke and ran good. Had a similar knock like yours though.
Driver Tom
02-09-2010 04:13 PM
1stgenatheart
10-19-2009 06:33 AM
robox
08-04-2005 10:56 AM
UnrulyNFS
28
06-20-2005 09:12 PM
Quick Reply: 06 dodge ram
