wiring problem
wiring problem
hey guys i have a question, i have a 2001 and my signal lights and brake lights are working. Is this a common problem ? could someone point me in right direction please.
My bet is it's a fuse you missed.
You can't always tell by looking.
Buy a tester from the autoparts. They sell one that tests the fuses in place, no need to pop them out, for under $10.
Don't forget to check under the hood.
Also check all body grounds on the bed, and the one that goes bed to cab. Don't trust the look, loosen it up,then re-tighten . A bad chasis ground will play heck with the tail lights.
ok i hang out in first gen area im new to these trucks, i didnt realize there were fuses under the hood, i did use a checker on fuses inside the cab. but there is no fuse labled stop or brake or signal inside.
wyododge
Jan 13, 2009 02:25 AM
charcoal600
Apr 30, 2005 02:34 PM
