wiring problem
hey guys i have a question, i have a 2001 and my signal lights and brake lights are working. Is this a common problem ? could someone point me in right direction please.
Need to proofread. I assume lights are not working!!!! Check fuses. Do marker lights and front signals work? Suspect TS switch for brakes and turn signals.
sorry not enough info, everything works but signal and brake lights, all fuses are good.
My bet is it's a fuse you missed.
You can't always tell by looking. Buy a tester from the autoparts. They sell one that tests the fuses in place, no need to pop them out, for under $10. Don't forget to check under the hood. |
Also check all body grounds on the bed, and the one that goes bed to cab. Don't trust the look, loosen it up,then re-tighten . A bad chasis ground will play heck with the tail lights.
ok i hang out in first gen area im new to these trucks, i didnt realize there were fuses under the hood, i did use a checker on fuses inside the cab. but there is no fuse labled stop or brake or signal inside.
