Wipers
Old Dec 21, 2004 | 08:30 PM
y22man's Avatar
Wipers
Ever since I bought my truck in May. The wipers would never work right. I think it is a wiper relay. But, I have no clue. Can you confirm
Conditions,
I have intermintent wipers. When I turn them on. It will follow the setting for aprox. 3 wipes. Then it will go to slow always on mode. Once it goes to this mode, when I put the wiper in the off position, the wiper will continue to run and stop anywhere it wants. I get it back to the bottom of the shield by turning on and off the wipers. Is it the relay? or do I have some other lurking electrical problem?
Old Dec 21, 2004 | 09:56 PM
KATOOM's Avatar
I just posted a topic on headlight trouble and found the Multi-switch could very well be my trouble and this Multi-switch controls wipers, headlights, turn signal, ect. So this might also be your situation.
Old Dec 21, 2004 | 10:22 PM
Hemi Cat's Avatar
Sounds like a wire getting hot and building resistance (low voltage). Check the switch connector and the wiper motor, and the bulkhead connector at the firewall. If the switch failed, check the wires in the connector.
Old Dec 22, 2004 | 05:05 AM
jgn's Avatar
jgn
Had the same problem on my wifes Chrysler van a few years back right after we bought it. If I remember correctly they replaced the switch.
Old Dec 22, 2004 | 09:57 AM
infidel's Avatar
There is also an intermintent module under the dash that occasionally goes bad
Old Dec 22, 2004 | 10:22 AM
hotdram's Avatar
Maybe that's why its called the intermittent module
When I bought my 97 new, the wipers totally quit the first day. Took it back and they replaced the wiper motor, sounds like you have different symptoms though.
~Rob
Old Dec 22, 2004 | 03:00 PM
Rattletrap1's Avatar
Now THAT's FUNNY
Old Dec 22, 2004 | 07:42 PM
y22man's Avatar
Ok, Thanks for all the replys. I will look sometime after xmas. I might have to bring this post back to life again. I don't know where some of that stuff is. But I will dig and find info.
Jay
Jason
Apr 19, 2004 12:40 PM
shaft
Dec 20, 2003 04:45 AM
doomgaze
May 7, 2003 08:56 PM
WA4SLC
Feb 10, 2003 04:54 PM
