winter questions
Old Oct 24, 2013 | 07:40 PM
Funker's Avatar
winter questions
Have a 99 Cummings with 140,000 km on it, I do not have any problems starting it in winter but I am wondering what I can do to make easier to warm it up.
Dual block heaters if able
Circulating heater
Hi Idle installed
Also I was wondering with that year of truck what kind of oil should I be using during winter... I have 15-40 in it right now
thanks
Old Oct 24, 2013 | 09:18 PM
Busboy's Avatar
Use 5W40 full synthetic oil and also synthetic power steering fluid I noticed a real difference on my 2001, I ran the same oil all year round along with a high mileage filter and changed once every year. You can also get the 3 cylinder high idle activated and a winter front is a must have.
Old Oct 24, 2013 | 10:49 PM
SIXSLUG's Avatar
Put it in an 80F garage...!!!
No, really, what Busboy says, unless you are in SoCal, then , not much...
Old Oct 25, 2013 | 05:24 PM
Midnite's Avatar
I wouldn't worry about adding an extra coolant heater--the stock heater does well there. The stock heater pulls 750 watts, so if you add another one you're really taxing the limits of a 120v 20 amp circuit.
The thing that made the biggest difference for me was a little pad heater that I RTV'd to the bottom of the oil pan. I think it's maybe 125 watts. Heating up the oil really helped my warmup times.
Don't forget a winter front as well--that makes a huge difference.
Old Oct 25, 2013 | 10:55 PM
Fiftygrit's Avatar
Get a rad cover so she`s not pulling so much air through, use to be able to get them from geno`s garage, air restriction is the easiest way to warm them up.
Old Oct 26, 2013 | 10:11 PM
SIXSLUG's Avatar
Just a heads up. Cover the radiator at the grille, not between the radiator and intercooler, as I did a few years back. This blows off the A/C refrigerant......
Old Oct 27, 2013 | 01:13 PM
patdaly's Avatar
Really? Mine never has. Of course I don't put it in till single digits, and pull it back out when double digits return, but I have never experienced any issues.
Old Oct 31, 2013 | 06:21 AM
Mike337's Avatar
You don't say where your from but I'll guess north of the Mason-Dixion.
I run Schaeffer Supreme 9000 Full Synthetic 5W-40 in Virginia with out any problems. Both trucks just have the standard block heater. I haven't ever found the need for a front yet.
Tedonlin150
46
Nov 21, 2011 10:45 AM
ryan10
Nov 1, 2007 01:07 AM
jgn
Nov 22, 2004 06:20 PM
dhe9
Mar 13, 2003 02:16 PM
rattle_rattle
28
Nov 11, 2002 07:43 PM
