Winter questions
Old Nov 21, 2004 | 08:42 PM
jgn's Avatar
jgn
Winter questions
First off can anyone tell me what to expect with a 2 WD 3500 dually as far as traction wise on bad winter roads? Second question, from what I hear you don't need the engine heater very often in cold temps but if I do use it is there a maximum amount of time it can be left plugged in?
Old Nov 21, 2004 | 08:58 PM
Rganser's Avatar
To answer the heater question, you can leave it plugged in if you want, but it will show on your electric bill. As far as traction, i just bought my 2wd also, so we will see how it goes.
Ryan
Old Nov 21, 2004 | 10:13 PM
Hemi Cat's Avatar
I've driven a lot of 2x4 duallies in the snow and the more it weighs the further it goes. When it weighs 13,000 it will go thru about 3 ft of snow unless there is ice under it. But when it finally does get stuck, just stop and call a BIG tow truck!!!
As far as the block heater goes, nothing wrong with leaving it plugged in except for the next month's bill. I would run a cord to the house and plug it in a half hour or so before I want to leave or get an automatic timer controll to turn it on at a specific time. Have fun in the snow!!!
Old Nov 22, 2004 | 12:24 AM
dalton4's Avatar
I agree with Hemi Cat. My 2WD LS dually does ok with weight in the bed. I keep the Lance 1121 on it during the winter. Without the camper I was throwing in 850#s of bagged sand over the rear axle.
Old Nov 22, 2004 | 12:59 AM
Ray,IN's Avatar
Cummins recommends a two hour plug-it time maximum, saying longer just uses more electricity needlessly. I have a 2500 CTD, with 55psi in rears/65psi fronts, and about 500lbs in the bed you can get around quite well. Place the weight over the rear axle and secure it for safety. Remember the B series Cummins engine weighs 940lbs + accessories, so the front tires will sink in mud and unpacked snow, creating drag.
Old Nov 22, 2004 | 06:20 PM
dalee's Avatar
I had my 12v last year and on one of the snowmobile trips the high was 5 and the lows were -22. It sat for two days NOT PLUGGED IN, all I did to start it was to let the heater grid cycle 2x and it chugged but started. Fall prep CHECK YOUR BATTERYS AND CHANGE YOUR FUEL FILTER AND RUN 25% -40% NUMBER 1. 4x4 more than doubles traction but don't try to be a hero and you will be fine.
Funker
Oct 31, 2013 06:21 AM
Tedonlin150
46
Nov 21, 2011 10:45 AM
ryan10
Nov 1, 2007 01:07 AM
dhe9
Mar 13, 2003 02:16 PM
rattle_rattle
28
Nov 11, 2002 07:43 PM
