window
Old Mar 8, 2007 | 08:43 PM
24valver's Avatar
window
driving along put down the passenger side window half way. Went to put it up and nothing happened. Help.. motor bad??????
Old Mar 9, 2007 | 12:36 AM
kycatpower's Avatar
Hard to say. Start with the easy stuff - have you checked fuses? Have you pulled the door panel and checked electrical plugs/connections? If you have a voltmeter - verify that you are getting voltage to the window motor. What is the temp like outside? (I'll assume it's nice out if you have the windows down - mine have frozen a few times due to water at the weatherstripping freezing.) I haven't priced out a window motor, but I would be sure before I spent the money.
Old Mar 9, 2007 | 08:55 AM
Copenhagenjunkie's Avatar
More than likely it's the switch. www.dodgeparts.com for a switch.
Old Mar 9, 2007 | 10:32 AM
zulusafari's Avatar
Will it not go up with either door switch, or just the driver's? I second that it is likely the switch.
Old Mar 9, 2007 | 10:54 AM
belgianmagic's Avatar
MY BOSS HAD THAT PROBLEM... THE WIRES TWEEN THE CAB AND DOOR IN THE BOOT... THEY ARE TWISTED SO THEY 'ROLL UP' WHEN YOU CLOSE THE DOOR...BUT THEY STILL BREAK ...THATS WHERE I THINK YOUR PROBLEM IS...LET ME KNOW, Flip
Old Mar 9, 2007 | 01:03 PM
ohiostate24's Avatar
Dang, calm down with the caps.
Rednecktastic
Aug 29, 2010 11:26 PM
raven392003
Oct 29, 2007 11:39 AM
Silverram03
Mar 19, 2003 10:49 AM
Snoking
Jan 7, 2003 10:55 AM
Mr. 45
Dec 28, 2002 01:21 PM
