Wheel spacer ring on passenger side 98 12v
Old May 12, 2005 | 09:43 PM
505diesel's Avatar
I just had my tires balanced and noticed a wheel spacer type of thing on the passenger side only. It's a ring that fits over the lugs about 1/4 inch thick. What is this? Is it a factory thing or should I take it off? Stock rims with 285 bfg AT's. Again it's only on the passenger side.
Old May 13, 2005 | 06:08 AM
DZLPWR's Avatar
Its a factory thing. I think dodge put it on there to solve a steering pull problem or something like that. Some people take them off with no effects, but id leave it on just to keep things happy.
Old May 13, 2005 | 09:43 AM
infidel's Avatar
Leave it on or take it off it makes no difference. Remember where it is though, sometimes they get stuck to the wheel and moved in a tire rotation. Yours many not be where it was originally intended to be.
Old May 13, 2005 | 09:02 PM
505diesel's Avatar
Cool, Thanks for the replies. Much appreciated. Glad I don't have to worry about it to much.
Old May 13, 2005 | 09:05 PM
J BODY's Avatar
It was part of the 8 million page TSB on trying to fix the truck when it pulled on brake applications. There was actually 3 different thicknesses of spacers, the thickest required the studs to be replaced to longer ones.
Old May 13, 2005 | 10:08 PM
fschiola's Avatar
My 1997 has one on the front passenger side also. Thanks for the heads up on them sticking to the wheel on rotations.
Old May 13, 2005 | 10:19 PM
DieselDaze's Avatar
My truck did not have a spacer when I purchased it and it didnt need one until I put the leveling kit up front. Now it pulls to the right when braking.
Old May 14, 2005 | 07:24 AM
infidel's Avatar
I think your trackbar needs to be longer.
Old May 14, 2005 | 07:47 AM
fschiola's Avatar
Maybe you could find one at a wrecking yard, but from what Jbody says it would be hard to tell which size you needed.
Old May 14, 2005 | 11:45 AM
DieselDaze's Avatar
You are probably correct.
The 2" leveling kit offset the front axle by almost 1 1/4".
Rich
Old May 16, 2005 | 06:06 AM
Amos's Avatar
Yeah that spacer was a "great" idea... My truck pulled hard to the right when braking until I took it off and set it on a shelf in the shop...
Old May 16, 2005 | 07:29 PM
fschiola's Avatar
Does the shelf pull now?
Old May 16, 2005 | 07:36 PM
smokindog's Avatar
The spacer is a "fix" for the infamous brake pull. I had one, but since upgrading to EGR brakes last fall it has been off. If you take it off expect some serious pulling to the side that it was on. Your previous owner should have told you about that.
Old May 16, 2005 | 07:51 PM
fschiola's Avatar
Anybody know what years they used them?
Old Nov 16, 2005 | 11:42 PM
Dave88LX's Avatar
Ah GREAT! So THAT is where my other wheel spacer is! I'm looking ALL over my stupid garage, floor, truck, under the truck trying to find the other spacer! Didn't really pay attention to when I was pulling it apart, I just thought to myself "Ain't hard to remember where this goes, just goes behind the wheel"...didn't know til now only one side though. Wish I'd have searched first, I could have saved myself the time of yanking my wheel off to see if I double-spacered it with one being stuck behind the wheel + the loose one I have.
Thanks.
Lost Lake
Feb 11, 2012 07:26 AM
megajoltman
Jan 6, 2008 08:39 PM
nfsommer
Feb 23, 2007 04:12 PM
HaulinBut
May 12, 2006 03:06 PM
Tigerfan
Mar 5, 2003 07:53 AM
