wet carpet
Old Jul 28, 2014 | 10:17 PM
torquefan's Avatar
Originally Posted by bigwayne
there is moisture coming out of the drain, but it's also coming out of where looks like the black box under the dash, there's a round looking part of the black box that appears like it's going through the firewall but i can't tell, and it's really leaking, could the drain be clogged enough where it comes inside? if i could figure out how to put a picture on here i would
Yep, the round piece is the back part of the drain tube. Sounds like it must have some gunk in there restricting it. As was mentioned, probe around in the drain tube gently with a piece of coat hanger and see if you can open it back up. You don't need to push it in very far.
Old Jul 29, 2014 | 12:57 PM
patdaly's Avatar
I wish I had a spare box to be able to take a picture of it, but the heater box kind of tapers to a V at the bottom where the round drain is. For the life of me, I can't figure out how it could ever leak into the cab, it should literally take it filling halfway up to start to leak, but it doesn't. I wonder if it is the fan blowing the drain water back thru the hole in the firewall......... I know for a fact mine has had the heater box out at least once, wonder if there is a seal......
Old Jul 30, 2014 | 03:41 AM
bigwayne's Avatar
i keep trying to clean the drain out, last night i believe i started to get alittle more water to come out, would it hurt to blow alittle air in, kinda like back flush it
Old Jul 30, 2014 | 12:14 PM
patdaly's Avatar
Shouldn't hurt, but be aware, the housing forms a valley down to the drain, so what at first feels line an obstruction is really the part of the housing that directs the flow.
Old Jul 30, 2014 | 06:48 PM
bigwayne's Avatar
i'm getting water out of the drain, i'm using a 8 gauge wire to probe around in there with, water streams down my arm, but it is still dripping from the housing inside
Old Jul 30, 2014 | 06:52 PM
bigwayne's Avatar
oh yea, another thing i've noticed is i don't hear the water sound coming from the housing. like it was full of water.
Old Jul 31, 2014 | 10:37 AM
patdaly's Avatar
If you can get to it, try running a bead of silicone around the tube where it passes thru the firewall.
The tube is molded right into the lower housing, so if there is a leak other than water being blown back and getting thru the hole in the firewall, you have a broken heater box.....
Like I said, I think it may be a case where after the box has been out once for a core exchange, it never seals right again.
Have you tried the 90 degree elbow yet?
Old Jul 31, 2014 | 05:27 PM
bigwayne's Avatar
not yet, fixing to go get one now, i'll put that on an see what happens, then i'll do the silicone, and if that don't work i'm going in, it ain't like i gotta lot of dash to take apart, ck back i'll keep you posted, thanks patdaly for all you're help, maybe it's as simple as an elbow
Old Jul 31, 2014 | 08:32 PM
Humblecowboy's Avatar
Had an 01 gasser at work that blew back. Went to the plumbers and got a copper 90 and it was a snug fit. Fixed the problem. And the gassers don't have the air filter box there to help block the back pressure
Old Aug 1, 2014 | 11:56 AM
patdaly's Avatar
You remember what size?
I like that idea better than the rubber..........
Old Aug 1, 2014 | 06:53 PM
That was a long time back but I think it was a 1/2" with the upset flare on it for soldering. If you know the ID of your rubber hose then just measure the ID of the 1/2" and 3'4" copper at the hardware store although 3/4 plus the upset seems to big best I recollect. I didn't even put a sealant on it to keep it in place and it was still on there when I walked out the door for the last time.
Old Aug 1, 2014 | 07:09 PM
patdaly's Avatar
Yea, I had forgot about the offset, it would have to be 1/2".
Now I wonder if a 1/2" rubber elbow would work..... I just bought what someone on here told me to..........
Old Aug 2, 2014 | 12:37 PM
You might even check the pvc and cpvc fittings. One of them may fit and cheaper than the copper. They have the pvc with threads too and that will be a different ID than the glue up one. Then there's that "crazy pipe" stuff (gray or black) for lawn sprinkler systems.
Old Aug 10, 2014 | 05:01 PM
bigwayne's Avatar
i found a vaccum elbow at advance auto, it has a flare on one end, it fits tight over the drain, and i think it's working, drove my truck to get it aligned, when i got home didn't notice any drippage, thanks everyone, ya'll been a great help
Old Aug 11, 2014 | 09:16 AM
patdaly's Avatar
Hope that's it, like I said, I went nuts, didn't believe it was possible to be that simple of a fix, 3 years later, still bone dry.
wexman
20
Nov 25, 2006 10:17 AM
54larry
Aug 29, 2006 01:15 PM
SMOKNISB
Jun 27, 2006 04:19 PM
Mslaughter
Jun 4, 2006 12:25 AM
garybg1
May 4, 2006 09:57 AM
