Water leaking in back of cab!!??
Old Apr 24, 2010 | 02:34 PM
DragonSlayer's Avatar
Thumbs down Water leaking in back of cab!!??
I got up this morning after the rain to the rear of the cab full of water.. Tomorrow I'm gonna search out the leak, possible from the 3rd brake light, but also could be from rear window. The truck should have been totaled after the p.o. had the trailer come around and hit the left side, the cab door was crushed along with the bed and cab floor. My question is, what holds the rear window in? Is it poly-urathane(sp) or does it gasket in? Thanks...
Old Apr 25, 2010 | 12:20 PM
royta's Avatar
I believe there is a gasket on the '96 trucks. I checked my '97 parts breakdown and it does list a seal part number for the rear glass. The newer 2nd Gen trucks use silicone in a tube instead of the seal.
Old Apr 25, 2010 | 12:39 PM
SIXSLUG's Avatar
Third blake light gasket is usually the winner in this scenario, however the previous damage may play in as well.
Get in it and have a friend hit it with the hose to be sure.
Old Apr 25, 2010 | 04:27 PM
DodgeRamdiese01's Avatar
was gonna suggest a hose also the seal arund the rear doors may be leaking from an improper fix
Last edited by DodgeRamdiese01; Apr 25, 2010 at 05:18 PM. Reason: didn't read the OP correctly maybe door seal:)
Old Apr 26, 2010 | 11:15 AM
justme-'s Avatar
3rd brake light opening gasket, and window gasket- when I got mine everyone was recommending sealing the brake light and top of the window gasket with silicone sealant. I did both, and tho I had to replace a bulb in the brake light, no leaks here.
Old Apr 26, 2010 | 08:32 PM
leprechaun's Avatar
I also had a water leak in the back seat.I searched it on this forum and came up with the 3rd brake light or the rear window.I sealed them both with silicon sealant.no more leaks.
Old Apr 26, 2010 | 10:03 PM
1985cucv's Avatar
3rd brake light silicone it and good to go!
Old Apr 28, 2010 | 03:08 AM
J-Keith's Avatar
Water Leaking in back of cab.
Just to add my experience. Yes it was my third brake light gasket. I just used silicon and that corrected the leak. Keith
Old May 1, 2010 | 11:21 AM
I made a gasket for the 3rd brake light, that slowed it down. I think it is more on the pass. side, I think I'll silicone the window next. Thanks for the replies, I'll let y'all know what finally gets it.
Old Oct 15, 2012 | 07:21 PM
way's Avatar
way
3rd Brake Light gasket
I have a gasket that can stop this leak !!
The problem is the factory gasket shrinks over time .. DO NOT USE SILICONE !!! If you do and try to remove it later , it would most likely break!!! The dealer wants $80-95.00 for the replacement light with attched new gasket .. Search ebay http://www.ebay.com/itm/320985630233...84.m1555.l2649
Old Oct 15, 2012 | 10:23 PM
joem's Avatar
I used travel trailer putty thats used on the corrner of the sideing, rolled a thin bead and dropped it into the grouve on the plactic lens, tightend the screws on a hot day and prefectly sealed
CoastalDav
15
Sep 7, 2008 10:49 AM
wlew
Aug 27, 2007 12:18 AM
dssimecek
0
Jan 24, 2007 11:58 PM
papaglock
Apr 14, 2006 07:02 PM
JoshPeters
Apr 3, 2005 08:13 AM
