Water getting in headllights
Old Jul 27, 2008 | 09:11 AM
Dodge Demon's Avatar
Have a problem with water getting into headlight, "sport headlight" when I wash at car wash with a wand, did a search and someone said drill a small hole in the bottom corners to eliminate the problem, what they didnt say was,- how small a hole,exactly where to drill the hole and does the hole have to be drilled at a angle. Anyone know?
These are not sealed units as there is a vent hole,"covered", in the top outside corner on the back side of the unit, actually I took the light out and hot glued all the way around the seam where the lens attaches to the housing ,thought i done a good job but still leaked,did it again,still leaked, scraped all the hot glue off,put some sort of "goop" all around the seam, havent tested it yet, wanted to know about drilling a hole just in case. If all else fails, thought I would try to take the plastic lens off and reseal it, anyone ever try to remove the lens, cant be on there too good as it leaks.
Old Jul 27, 2008 | 09:51 AM
johnh's Avatar
i have had tha problem ever since the truck was new, i just live with it
Old Aug 2, 2008 | 09:33 PM
Fire475's Avatar
Are you sure it is the lens and not the bulb seal in the back of the headlamp given you the issue. if it is the lens give it up and buy some aftermarkets lamps. cause once you get moisture in a lamp you cant get it out most of the time
Old Aug 2, 2008 | 10:12 PM
update
Pryd the lens off,found were it leaks, resealed it with some sealent,good to go,no more leaks.
M Penwald
14
Mar 26, 2011 08:41 PM
Flatbed24v
15
Oct 31, 2008 11:39 AM
brown8182
Feb 19, 2007 08:37 PM
kawi600
Jun 12, 2006 09:05 PM
papaduck
Oct 3, 2005 07:02 PM
