volatage at horn wiring
Old May 21, 2007 | 12:41 PM
smokeyram's Avatar
I swapped in a cheaper set of air horns over the weekend, and in stead of wiring direct to a 12v source, i hooked up the hot wire right to the horn wire.
Anyone know if im getting 12v there or less? just didnt pack the punch I was expecting.
I hooked it up this way so I wouldnt have to mess around with a seperate horn switch.
Old May 21, 2007 | 01:09 PM
John Faughn's Avatar
I do not think that there is enough power on that circuit , limited by relay .
Old May 21, 2007 | 03:36 PM
BarryG's Avatar
You could use the hot horn wire to trigger a new relay that is also fed by 12v to power the new horns. That way you still wont need a seperate switch and they will blast when you honk the regular horn and will pull their power from the 12v source.
Old May 22, 2007 | 10:42 AM
In most cases , relays are operated by grounding one side of the coil [ inside of the relay ] , the buttons on you steering wheel are the grd. for the relay .
Old May 31, 2007 | 08:25 AM
smokeyram's Avatar
ok, ill have to tear the wiring apart and put the supplied relay in this weekend.
wyododge
Jan 13, 2009 02:25 AM
chvyhs
Jul 2, 2008 02:27 AM
Evildiesel
Jul 2, 2006 06:39 PM
charcoal600
Apr 30, 2005 02:34 PM
Sidewinder
Jul 14, 2004 05:42 PM
