Vacuum Pump Seals
Vacuum Pump Seals
I found my notes on where I went to a bearing/seal supplier with a kit for the vacuum pump. If yours is leaking between the vac pump & power steering pump, try these seals. (1 each - i think but don't have notes)
Large O-ring size 039
Small O-ring size 132
Seal 28 X 38 X 7
Seal should be double lipped. O-rings could be Viton which will stand up to oil &, diesel etc.
You'll also want a Cummins gasket between the block & vac pump. Perhaps your old one will work, perhaps you'll glue it with something. I bought a gasket but don't have the number.
Destructions are available online for changing the seals.
Seal 28 X 38 X 7
I've put 3 seal kits in mine (double lipped) and it was still leaking. I discovered I had some deep scratches on the housing so I decided to use RTV on the last rebuild...problem solved.
jimbo486
05-08-2016 06:07 PM
DodgeDawg2500
12-07-2011 01:22 PM
amartinson
0
05-04-2003 01:55 PM
