Track Bar
Old Oct 24, 2006 | 02:17 PM
deezeldude's Avatar
Track Bar
Installing a aftermarket MOOG track bar in hopes of curing the death wobble...i need to know if this is an "in & out" Install? will it just pull out and go back in or is it under pressure? info asap if possible! thank you.
Old Oct 24, 2006 | 02:24 PM
Kemble's Avatar
If you are replacing it on level ground, there should be no pressure on it. Should be an in and out type job. Good luck.
Old Oct 24, 2006 | 02:49 PM
deezeldude's Avatar
thanks alot man.
Old Oct 24, 2006 | 02:59 PM
Mcmopar's Avatar
30 minutes if you take your time
Old Oct 24, 2006 | 06:46 PM
infidel's Avatar
Helps to have two people.
With the tires on the ground another person turning the steering wheel can move the bar end several inches, helps lining it up.
Old Oct 25, 2006 | 09:50 AM
amartinson's Avatar
You will notice that the Moog unit is considerably heavier than the stocker. I have put a few on at work. Nice piece IMO. Easy install.
CTD2001
Aug 22, 2009 10:03 PM
Dinner
May 29, 2007 02:02 PM
kwillis-a
Jan 25, 2007 09:10 PM
dieselgeek
Mar 19, 2003 09:15 PM
MAX340
13
Nov 2, 2002 07:47 PM
