Tire chewing
Old May 29, 2005 | 06:06 PM
TxDiesel007's Avatar
Tire chewing
Guys,
I know this sounds kind of funny when you first mention it, but my CTD has been notorious for chewing up the outter edges of the front tires only, The tires are liberator 285's on 16x8 rims with only 4000 miles, due for their first rotation at next oil change. Today while airing up the tires and checking their pressure, i noticed both of the front tires were "chewed" up on the edges. I figure its from when i steer to either side.. Could this be the ball joints? or the steering trackbar etc... where should i start? what can it be? and what do I do? Fellas.. thank you once again for your time, patience and your help..
TxDiesel007 "Rick"
Old May 29, 2005 | 07:12 PM
BigBlue's Avatar
Ball joints, tie rod ends, alignment, track bar, the fact it's a dodge front end.
Old May 29, 2005 | 09:54 PM
Thanks Big blue!!
i somewhat figured it be that from readin on some of these posts.. Im gettin some new parts soon.. BOMB bucket will be empty again... why dont we have a cryin smiley here??
Tx
Old May 30, 2005 | 07:23 AM
out_drsman's Avatar
Tx - I had the same thing happening to me. Replaced the sway bar bushings, shocks, tie rods, and had the alignment done to the "good" specs that are on this site somewhere. I have checked the ball joints with the up/down and in/out test and they seem fine. All to say that I still have wear on the outer edge. You might start with the track bar and see if that helps before spending the $$$ for the other stuff unless you can tell that those other parts are shot.
Just my .02 but good luck and let us know how it turns out.
Josh
Old May 30, 2005 | 02:01 PM
Will do outdoorsman..
Thanks!
Tx
Old May 30, 2005 | 10:08 PM
Haulin_in_Dixie's Avatar
take it to an alignment shop and maker sure the toe in is set to 0.
Old May 31, 2005 | 08:44 AM
Mopar1973man's Avatar
I agree more the HiD on this one... I would say the a good chance that toe is out...
Old May 31, 2005 | 04:38 PM
Cowhand's Avatar
I concur....definitely toe. I had the same problem until I ditched the stock steering setup.
Your truck is the same year as mine, so I'm assuming you have the same tie rod setup. The problem with the "y" link tie rod is that every time the front suspension compresses, it causes the front tires to toe out. The tie rod ends are notorious for getting sloppy after a few miles too.
I spent a boatload of money on alignments and TRE's in the last few years, couldn't keep it aligned more than a few weeks. Since I've "re-engineered" the front end I haven't had any problems at all...
jk6140
Sep 5, 2007 03:35 PM
GasganoFJ60
Apr 14, 2007 10:36 AM
curts99
Dec 20, 2006 07:09 PM
