sway bar links
Old Mar 21, 2014 | 04:52 PM
knightowl's Avatar
sway bar links
am i the only one having trouble keeping sway bar links on my truck this is my third set in a year,the last ones being moog problem solvers (lasted 3 months) the truck is stock and not lifted and is not abused is there a solution to this or is this normal any suggestions would be appreciated
Old Mar 21, 2014 | 10:29 PM
ripping r's Avatar
I have the bd links and love them. price is not to bad at 105 for the set.
Old Mar 21, 2014 | 10:52 PM
gorms's Avatar
I had problems with the rear links wearing out, so I replaced them with straight universal links and angle brackets. They were about $10, already had the brackets. Haven't tried to do this in the front yet but it has held up for several years now.
Old Mar 22, 2014 | 12:34 PM
SIXSLUG's Avatar
That kind of issue makes me wonder if you are getting the right parts, or if they are getting installed properly.....
Old Mar 22, 2014 | 09:09 PM
knightowl's Avatar
sway bar links
pretty sure i installed them right, easy enough to do. but is possible that the parts may be wrong, though they did look the same as the originals i think i am going to try the dbs as i am mostly on gravel and ruff roads they do look like a stronger setup. thank you all for the replies
Old Mar 22, 2014 | 11:05 PM
DIESELWRKS's Avatar
go on www.genosgarage.com
look at the maxx links
they have a better warranty.
I have had mine on for 5years I think I had a issue with a bushing due to me having installed it slightly off center and 5 years later the bushing busted. they sent me a new upgrade kit for both sides.
plus the links are cheaper $ than all others.
Old Mar 23, 2014 | 12:25 AM
seafish's Avatar
X2 on the BD links...just installed them...nice design, beefy, easy to install though you DO need to drill the axle mounting tab out to 14mm for the BD bolt to fit!!
Old Mar 23, 2014 | 12:12 PM
SIXSLUG's Avatar
Good luck...I am going to need to do mine soon, let us know how it goes!!
OneHigh4x4
Aug 27, 2007 07:54 PM
peski32
May 14, 2007 06:11 AM
68dodge
Jun 25, 2006 11:28 PM
Inferno Ram
Jun 11, 2006 10:53 AM
