Stuck on defrost, is it this vaccum line or something else?
Old Sep 11, 2008 | 01:04 PM
sleepr tsi's Avatar
Trucks been stock on defrost or a while, with winter coming I feel like I should fix it now. So, just taking a quick peak, I saw
So, is this the problem or do I need to look some place else, and if it's not the problem, what does this go to?
Old Sep 11, 2008 | 01:23 PM
06RAM2500's Avatar
Check around for a hose. Obvious that the controls aren't getting a vac.
Old Sep 11, 2008 | 01:38 PM
Lil Dog's Avatar
What is that uncapped line for? Does your 4WD still work? Plug that open line off just above the booster with a vacuum rubber cap.
Old Sep 11, 2008 | 04:43 PM
Barryn's Avatar
My dually did the same thing and I found the same fitting uncapped. Fold a piece of duct tape over that open fitting and see if things don't straighten out.
Old Sep 11, 2008 | 07:49 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Mine looks like this......
Old Sep 12, 2008 | 01:02 AM
sleepr tsi's Avatar
I did a quick look and didn't see anything. I'll try capping it off, but I guess what I'm wondering is the missing line the ac control or is it for something else?
Old Sep 12, 2008 | 01:57 AM
kthiemann's Avatar
It's hard to tell from that pic. but at that junction there should be an input from the vacuum pump, and 3 output lines, one to the cruise control, one to the transfer case if you have 4 wheel drive and one to the hvac control if my memory serves correctly. will take a look at my truck in the am to make sure I'm correct.
Old Sep 12, 2008 | 08:20 AM
patdaly's Avatar
Easy enough, before you cap anything, with the truck running, put your finger over the barb and see if you have any suction.
If not, then look down and you will find you vacuum supply line. You may have to track it back from the pump on the engine.
Old Sep 12, 2008 | 09:18 AM
sleepr tsi's Avatar
It's got vaccum, so that goes to something. I'll try to just cap it today amd hopefully that works.
Old Sep 14, 2008 | 01:39 PM
ScottN's Avatar
The missing line probably goes to your cruise control. Located under the D/S battery. The cruise line also gets brittle and breaks, you may want to replace it.
IMC
15
Nov 25, 2011 01:29 PM
2006BLKMegacab
Dec 18, 2010 11:06 AM
TXJosh
Apr 25, 2009 05:58 PM
Baja
Jan 29, 2008 08:17 PM
tyssniffen
Apr 12, 2006 04:29 PM
