Stock wheel spacer
Old Feb 20, 2006 | 12:32 PM
firehawk's Avatar
Stock wheel spacer
I was doing brakes on my truck today and noticed a 3.5mm spacer behind the right wheel. It was held on by clips so Im assuming it was there from the factory. There is not one on the left side. Has the one on the left side been lost? Can I take the right one off or should I find one for the left side. Truck is a 99 2500 with the stock chrome steel wheels.
Thanks in advance
Old Feb 20, 2006 | 01:24 PM
Shovelhead's Avatar
Administrator / Scooter Bum
The shim was a "FIX" for the pulling to one side problem Dodge had when the 2nd Genners first came out.
I'd put it back where it was and not worry about it.
Old Feb 20, 2006 | 01:45 PM
firehawk's Avatar
Thanks, Ill put the "fix" back. Too bad they didnt come out with a shim to "fix" the lift pump.
99 cummins's Avatar
This would explain alot of my braking problems nobody has been able to fix. I don't have a spacer in mine.
Old Feb 20, 2006 | 06:15 PM
infidel's Avatar
Not all trucks come with the fix and there are three different thickness that can be on either the left or right side.
Most people have found the spacers don't do anything and often stick to the back of the wheel and get moved in a tire rotation.
Old Feb 21, 2006 | 10:08 AM
Amos's Avatar
I agree with Infidel, I had the spacer on my passenger front wheel and every time I braked hard it would pull severely to the right. I took the spacer out, hung it in garage and the truck now stays perfectly straight even in a panic stop situation. For my truck it was more problem than solution.
Old Feb 21, 2006 | 10:20 AM
RustyJC's Avatar
The brake pull problem is addressed in great detail in TSB 05-03-97/TSB 05-04-99. This TSB is 27 pages long as presented and goes into much detail in how Dodge diagnoses and (hopefully) corrects this problem. The use of shims is addressed at the bottom of page 18 (Item 12) onward.
Rusty
gkainz
Nov 17, 2005 07:31 AM
505diesel
14
Nov 16, 2005 11:42 PM
tbishop1
Sep 20, 2005 02:16 AM
I PASS GAS
Feb 18, 2004 08:52 AM
Stamey
Feb 17, 2004 07:45 PM
