stiff steering and no return to center
Old May 16, 2007 | 08:40 AM
gizzi's Avatar
Every is new, 3rd gen track bar, balljoints , ect. everything except steering box and pump is new... and the darn thing is stiff to steer and does not return to center...whats the problem?? gettin frustrated
Old May 16, 2007 | 08:59 AM
John Faughn's Avatar
Pressure test pump , disconnect rod from steering box to see if you can find a tight part , frt. end off ground .
How was it before you did the work ? maybe something is amiss with what you added ?
Old May 16, 2007 | 10:34 AM
Meat Man's Avatar
I had all kinds of steering problems with my truck when I first got it. The final fix was to remove all the factory PS fluid and replace with ATF and a second new (reman) PS box. The dealer thought that the first new box was defective.
Nathan
Old May 16, 2007 | 01:01 PM
kawi600's Avatar
I second pressure testing the pump. I had that happen when I replaced my steering box with the PSC. The stock pump was just old and needed replacement.
as far as I know, ATF is not recommended in these pumps.
Old May 16, 2007 | 11:01 PM
Meat Man's Avatar
I would have thought that ATF is not the right thing to use either. But after all the issues I had with getting the steering lined out just after I bought it...I figured that if that is what fixed it, I'll stick with it.
I'm not saying that the dealer is always right, but they said they do it quite a bit for the trucks that seem hard to steer (excessive force) and wander.
Nathan
Old May 17, 2007 | 07:46 AM
gizzi's Avatar
Well i checkedit all out last night. Disconnected everything from the steering box, nothing is binding up anywhere. I rotated the steering wheel and made sure it was center centered and the pitman arm on the steeringbox was in the right location. everything checks out ok. has to be a back steering box. i guess
Old May 17, 2007 | 08:40 AM
I'm still leaning towards the pump , anything lose in steering box , or tight ?
Old May 17, 2007 | 09:07 AM
gizzi's Avatar
It feels tight (abnormallytight), but who knows. I think the box is shot.
Old May 17, 2007 | 04:46 PM
JKM's Avatar
JKM
If it feels tight , and won't return to center , Back off the overcenter adjustment 1/4 turn at a time and see if it helps the problem. If it does not help the problem after a full turn , then it is severely out of adjustment , or something else is wrong.
Scotts_D250
Jul 10, 2011 01:05 AM
jmlcolorado
Jun 10, 2011 07:14 PM
SundayMoney
May 30, 2010 08:19 PM
ctd4stan
May 18, 2009 02:56 PM
