stereo problems
Old Feb 26, 2007 | 09:45 PM
deaconn's Avatar
stereo problems
just put in new stereo i had the infinity system in my truck. so when i hook it up there was no sound. and after reading some post on here it was suggested run the speaker wire straight through to the speakers. which i did but now i have no power. hook up the lead and the ground check all the fuses in truck and stereo still nothing.(had power before running straight through to speakers}. am i missing something .thx
2001 quad cab 5 inch skyjacker lift 4 inch pipe 108000 miles on 35 bfg's that's all I known.
Old Feb 26, 2007 | 09:55 PM
BPM's Avatar
BPM
From: Shreveport LA for 10 days at a time, Groveton TX the rest
Remote Wire
When I did mine I had the same problem with not having any sound come out of the speakers. When you took out your factory radio there should have been a wire that was clipped onto the back of the radio independent of the wiring harness. To solve my problem I took that wire and hooked it up to the remote wire of the harness (I think that it was blue.) Once I did that it worked. Hope this helps.
Old Feb 26, 2007 | 09:58 PM
K5KRAZIE's Avatar
That is the same thing I did, you have to turn the amps on in the doors and that blue wire on your aftermarket radio will do it.
Old Feb 26, 2007 | 10:04 PM
deaconn's Avatar
stereo problems
can i hook it up with out the harness just running straight to speakers. and I'm not getting any power is there something esle that should be hook up other than the lead and ground
2001 quad cab 4wd 5 inch skyjacker lift 4inch pipe on 35bfg's 108000 miles that's all I known
Old Feb 26, 2007 | 10:13 PM
BPM's Avatar
BPM
If you have run your wires straight to the speakers then you saw the amp mounted to your speakers. When I changed my speakers I made the mistake of cutting one of them completely off and just plugging in the speaker wire and I couldn't get it to work. So I had to resplice all of the wires going into the amp and then it worked again. I don't believe that running the wires straight to the speakers will work with an Infinity system. I think that you are going to have to use the harness and connect the remote wire in order for it to work.
Old Feb 26, 2007 | 11:01 PM
yfz450guy's Avatar
you are correct. i don't think it is possible to bypass the infinity amps on the speakers.
you can get new speakers for the doors for under a couple hundred bones.
Old Feb 27, 2007 | 07:26 PM
deaconn's Avatar
stereo problems
okay I'm not running into the stock speakers at all. I have after market speakers and ran straight from the stereo to the speakers bypassing all stock parts still can't get power to the stereo .
2001 quad cab 5 inch skyjacker lift 4 inch pipe 4wd afe 108000 miles that's all i known.
Old Feb 27, 2007 | 07:59 PM
clutch1's Avatar
Ground, constant power, and power with key on should be all you need for the HU.
Old Feb 27, 2007 | 08:13 PM
deaconn's Avatar
stereo problems
I'll try it again. thx
Old Feb 27, 2007 | 08:31 PM
yfz450guy's Avatar
ok, i just did the same thing with amps and such. i memory serves me correctly. the pink is the constant hot red is keyed hot or (visa versa) and the ground is black. i took the black ground that was snapped on the back of the stock radio and the black wire from the aftermarket harness and crimped a spade on it and put them together.
http://www.autotoys.com/New_Tech/Wir...ire_colors.htm
DJ Turbo.
Oct 13, 2011 09:11 PM
ohiostate24
May 6, 2007 08:31 PM
beandrew
Mar 3, 2007 01:56 PM
WheelingCJ5
18
Jan 14, 2007 11:34 PM
DF5152
Dec 29, 2002 05:28 PM
