ring on front rotor?why only 1?
Old Jan 6, 2007 | 08:15 AM
neverhme's Avatar
theres a ring on the rotor, goes over wheel studs, why only one? which side does it belong on.?
Old Jan 6, 2007 | 08:19 AM
RustyJC's Avatar
This was a "fix" for brake pull. If the truck were pulling to the left, a spacer would be put behind the right front wheel - and vice versa, of course. So, it could go on either side depending on that particular truck's problem - and most trucks probably don't even have them.
There's a lengthy TSB that explains all this.
Rusty
Old Jan 6, 2007 | 10:09 AM
infidel's Avatar
Besides not often working to correct pull the bad thing about the spacer ring is that it can stick to the back of the wheel and get moved anywhere during a tire rotation. I know of people who have found the ring on the rear.
Old Jan 8, 2007 | 08:17 AM
VADSLRAM's Avatar
Ring? What ring? How big? I did a search for any TSB on it and couldn't find anything.
Old Jan 8, 2007 | 08:22 AM
RustyJC's Avatar
Here ya go - TSB
Rusty
Old Jan 8, 2007 | 08:45 AM
neverhme's Avatar
this truck had it since new, just trying to chase down a wierd front end, had a shop do dome work,I cant remember what side it came on??
Old Jan 8, 2007 | 09:44 AM
VADSLRAM's Avatar
I had read that one. It links to a gear nut puller???
and Chassis Dynamics Diagnosis ??
did I miss the ring?
Old Jan 8, 2007 | 09:48 AM
RustyJC's Avatar
From page 19:
RAM 2500/3500 SERIES WHEEL SHIMS
AR 1 04863759 Wheel Shim, (2.0 mm)
AR 1 04863760 Wheel Shim, (3.5 mm)
AR 1 04863761 Wheel Shim, (5.0 mm)
AR 1 04864549 Wheel Shim Kit
1 04863762 Wheel Shim, (6.5 mm)
8 04864185 Wheel Studs, (9116 - 18 UNC threads) (3850 lb front axles)
8 04864187 Wheel Studs, (9116 - 18 UNC threads)
(4850 lb front axles with single rear wheels)
8 04864188 Wheel Studs, (9116 - IS UNC threads)
(4850 lb front axles with dual rear wheels)
There they are.
Rusty
Old Jan 8, 2007 | 10:00 AM
VADSLRAM's Avatar
Thnx so very much!
You Da Man
sgrooms
21
Apr 8, 2008 11:17 AM
HaulinBut
May 12, 2006 03:06 PM
hotdram
Oct 27, 2005 06:57 PM
steve99ram
Jul 17, 2003 07:45 PM
4x4
15
Apr 28, 2003 08:49 AM
