reverse light woes.....
Old Nov 16, 2005 | 11:17 PM
96RAM's Avatar
Up here in sunny bc it seems all the recent rain and humidity has got to my reverse light. It has been working intermittently and getting worse. Today it didn't work at all.... playing with the gear stick when selecting reverse seems to help sometimes.... any suggestions on where to look first?
Old Nov 17, 2005 | 07:35 AM
J BODY's Avatar
I'd go straight to the back up lamp switch. Two wire switch on the side of your trans. Put it in R with the key on and check your voltages.
Old Nov 18, 2005 | 12:48 AM
96RAM's Avatar
Funny I was looking for a voltage meter today for something else..... guess it'll really come in handy then
thanks!
Old Nov 21, 2005 | 08:21 AM
CRSmith's Avatar
My backup switch looked fine on the ohm meter, but when I bridged terminals on the plug with a wire (bypassing the switch), the lights would light. So you may get a false indication from testing w/ the ohm meter.
Old Nov 25, 2005 | 04:43 PM
96RAM's Avatar
Thanks I haven't got around to testing yet
Old Nov 25, 2005 | 04:59 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Mine quit working on my 96 one time. I crawled under the back of the truck and started pulling wiring plugs apart and cleaning them with contact cleaner. One of them was pretty nasty inside, once cleaned my lights worked just fine.
Old Nov 25, 2005 | 07:21 PM
Stamey's Avatar
The curious thing about my 99 AT, was the reverse lights started working intermittently, but the "Park/Neutral" part of the neutral safety switch worked fine. I figured both parts would mess up at the same time, but I guess not. All was well after replacing the switch, per recommendation of members here.
Chris
peobryant
Mar 23, 2012 03:23 PM
barngal6
19
Feb 4, 2008 05:47 PM
TEXAGS'98
15
Dec 18, 2004 08:27 PM
DodgeCowboy
13
Dec 30, 2003 09:26 PM
TX Ram
Apr 11, 2003 05:56 PM
