replacing front brake pads
Was just wondering how hard it is to put new ones on, Got the new one's already but need to know how much time involved in the change. Ive done a ford before but don't know if the dodge is more difficult or easier. Any info is appreciated.
Re:replacing front brake pads
The front pads are pretty easy to do on the single piston calipers. If my memorys serves me correct you will need a 3/8 allen key or equivalent to remove the two slide pins that hold the caliper tot he truck. The rest is pretty simple but make sure you lube the slides with high temp grease before putting it all back together.
Good luck
Jason
Good luck
Jason
I need to change mine out on my new truck. I helped a friend out on his 2001 4x4. I have changed many brake pads out on many vehicles, but we could not get the pads off. there were these little thin, metal clips that we couldnt figure out.
can someone tell my what the trick is with these clips?
or atleast tell me how to change them on a 2001 4x4?
dochawken
Jun 29, 2012 01:04 AM
93-12Smoke
Aug 28, 2011 12:22 AM
Chip
14
Jun 21, 2009 03:59 AM
