red head vs napa steering box
Also ordered this steering stabilizer bar from http://www.dodgeramsteeringstabilizer.com/ as I've got pretty big tires and do a lot of offroad, plus I got a heavy camper
Redhead boxes are supposed to b e good.
What kind of warranty on the NAPA?
The DSS will help tighten things up, but I didn't find mine to be a "wonder" fix like some have stated, just beefs up the frame and box area...good part.
Oh, yeah, a new box and brace are gonna do you good.
Some guys throw a DSS at a loose front end say it solved all their front end problems, but if other stuff is worn out I can't see how it could.
The box is the only part original to my truck regarding the steering components, when I replace it I will see if their is any improvement over everything else. My box was a little loose in endplay and the dss helped it a lot.
also my pump is beyond shot, spewing oil and groaning
ya, it's past time
Please don't waste you time on a NAPA box...Trust me....My truck is a highway truck and never sees any off road driving...I went through 3 NAPA boxes...in 5 years
Then I got the Redhead box...OMG...Side by side, and comparing the boxes...The Redhead is hands down...No play in that box...
I could tell the difference in driving with the Redhead box...Very nice thight steering..100 times better than a new NAPA box...
Over a year and the redhead box is still working great...
might not be your box. try flushing or replacing the fluid first. i had the same problem, replaced with synthetic PS fluid and not a problem for a few years. although it is synthetic, i would say i am well overdue for another flush/top-up . . . but needless to say it has been great so far, without issue through some pretty cold winters . . .
Hmmm....I know when I talked to them a while back...They where starting to buy NAPA boxes to rebuild at their shop...I guess a few people must of keep their cores...and they where running out of cores..
While I have not used a NAPA box I did/am using a redhead. Couldnt be happier with it so far. I did use a napa pump though again so far so good with that as well. There was a huge difference between the stocker and the redhead now the stocker had 280k on it so I would have been quite suprised if I hadnt seen some noticable improvement.
Redhead. Night and day difference compared to the NAPA boxes.
For the time and money I have spent on steering gears, Harvey knows his stuff, and definitely builds the superior product.
I'm on my second reman box, they both ended up in the same shape as the O.E. one after a year or two. One was an auto zone (actually that one started leaking internally after 2 years) and the next/current is a Napa. Napa was tight at first, but after a month felt just like the old box, too much slop on the input shaft. This is with a good track bar, steering stabilizer, ball joints, alignment, you name it. Doesn't really wander much unless the road dips, but the correction in the wheel needed is aggrevating. Next will be a redhead, which is supposed to be a different box all together, which I think is the real fix.
