Radiator fluid loss from 1999 cummins NEED HELP!!!
Old Oct 25, 2006 | 09:15 PM
dodgeman911's Avatar
1999 Dodge cummins 24V with 200k. 4x4, Ex Cab. Dually, Air Exhaust, 4" Exhaust and chipped.
What is happening is that I am losing radiator fluid between head and block on the passenger side of motor.
Is this a common problem and a typical head gasket repair, or are there other things that could be causing this??
Any help is appreciated.
Thanks!!
Old Oct 25, 2006 | 10:44 PM
displacedtexan's Avatar
I'd put money on a cracked block. And I'd put more on it being a #53 casting...
http://www.stamey.info/Truck/Cummins53BlockFAQ.htm
I know it's not what you wanted to hear, but it is fixable, there have been many that are pleased with the lock-n-stich repair.
Old Oct 25, 2006 | 10:46 PM
I just reread your post... Depeding how hot your chip is you MIGHT have blown a HG, how much boost are you seeing? (you do have gauges, right)
And welcome to DTR!
Old Dec 7, 2006 | 02:10 PM
VTFL60's Avatar
The #53 Cummins boat anchor. Yes you got the same problem that many others have with this block. I don't know what is happening on mine but I'll post something if I get any satifaction. So far Cummins doesn't consider this a big enough issue to do anything about.
Old Dec 8, 2006 | 02:44 PM
alexschultz1's Avatar
the o-ring on the water pump will blow sometimes and cause the coolant to leak out of there. you have to buy a new water pump to fix that problem there like $100
Old Dec 8, 2006 | 08:35 PM
Copenhagenjunkie's Avatar
Let's all jump on the #53 boat anchor bandwagon. That's 2 thread's about 99's leaking and most posters just pounce on the thread with OH GOD IT'S A #53. Just cause it's leaking water don't mean squat. I love my 350K+ miles #53 block!
Now back to regular programing.................
If the leak is under the thermostat on the corner of the block then it's just the head gasket and a very common place to leak. I have some pics in my... oh heck that place where we have pictures!.
Old Dec 16, 2006 | 11:52 PM
Bart Timothy's Avatar
The 53 blocks usually crack and leak a couple of inches below the head gasket line. If the water is coming out above that point you've blown a haed gasket, which isn't all that uncommon depending on what you mean by "chipped". Stacking 2 timing boxes would do it.
Old Dec 17, 2006 | 06:11 AM
Dodge@KY1997's Avatar
I am going to go with a HG dodgeman...That is where mine is/was leaking at. Right where the block and head meet, behind the thermostat housing. It was a little hard to find. But some sealer in it to by time till I can pull the head.
8liter
Sep 22, 2012 10:19 AM
ewhman
Mar 3, 2012 12:29 PM
jlipskoc
Mar 9, 2011 06:13 AM
patdaly
Oct 20, 2008 08:26 PM
cbrxxtreme
24
Jul 17, 2008 03:30 PM
