Question for "rock solid steering" owners
Old May 16, 2007 | 06:03 PM
the496rocket's Avatar
I just installed the rock solid bushing in my truck tonight, made the truck drive great, It says right in the instructions that it will take a bit to get the new bushing broken in, and the steering will be stiff until then, my steering is fairly stiff after just having put it in, the steering wheel will not hardly return to center at all, just wondering about other people that installed one, and how long it took before it was easy to turn again.
Eric
Old May 16, 2007 | 10:05 PM
SilverRam3500's Avatar
Good to know b/C I'm installing this this weekend also!!?
Old May 16, 2007 | 10:40 PM
J Lent's Avatar
It took about 1000 miles to break in, but feels great now. You could put some grease in around the shaft to aid in steering.
Old May 17, 2007 | 08:22 AM
I used some anti-seize when I first installed the bushing, maybe I should use something different? white lithium?
Old May 17, 2007 | 08:42 AM
macattack_ga's Avatar
for other lurkers:
http://www.rocksolidramtrucksteering.com/
Old May 17, 2007 | 09:21 AM
hamilton71801's Avatar
One more thing to remember, when it gets below 40 degrees mine gets stiff (steering shaft). I called them and he said that the metal probably expands making it tighter on the bushing. I used moly grease on mine and it was loose from the beginning.
Old May 18, 2007 | 09:17 PM
bigjohn862's Avatar
how hard is it to install
Old May 18, 2007 | 11:46 PM
not too bad, I took my column out, that was the hardest part, you can do it in the truck, which I dont think would be too bad either. My steering is starting to get easier, But I have a boost gauge on my column, and now it dont work, I must have broken the tubing oh well, more to fix.
Old May 19, 2007 | 02:24 PM
J Lent's Avatar
Not too bad. I used a grinder to cut the spring retainer while the column was still in the truck. Everything else just pops out with a screw driver.
Zach
21
Sep 7, 2016 09:02 AM
mr bill
Nov 28, 2010 08:27 PM
CODODGE2500MAN
May 21, 2010 06:09 PM
the496rocket
Feb 20, 2008 08:41 PM
lews930
Oct 14, 2007 10:11 AM
