Question on headlights
Old Aug 18, 2005 | 12:08 PM
hemertwv's Avatar
My 2001 3500 won't run on high beams, when you flick the switch the headlights go off, I have replaced/checked the builbs and no difference.
When you pull the high beam switch back the high beams come on while you are holding it, but as soon as you let it go, the high beams go out, I am suspecting the switch, any other ideas.
If it is the switch how hard is it to replace the switch on the column.
Thanks Walter
Old Aug 18, 2005 | 12:28 PM
phox_mulder's Avatar
Re: Question on headlights
Yup, it's the switch, common problem.
You might try spritzing some contact cleaner in there and excersizing the switch before you go shell out for a replacement.
phox
Old Aug 18, 2005 | 01:21 PM
hemertwv's Avatar
Thanks, I will try that tonight
Old Aug 18, 2005 | 01:46 PM
hemertwv's Avatar
Ordered a switch since the spray didn't work, just tried it, ouch, 72 bucks canadian
Old Aug 18, 2005 | 07:28 PM
infidel's Avatar
Re: Re: Question on headlights
phox
This has always worked for me.
It's my belief that dirt cruds up the high beam contacts when the brights aren't used much.
Just working the switch back and forth occasionally prevents dirt build up for me, lights don't have to be on.
If you have to replace the multi-function switch it's not too bad of a job.
Dealer only part though, about $70
Old Aug 18, 2005 | 07:44 PM
Marine's Avatar
Veteran: Marine Corp
This happened to me, but it was the bulbs. Both brights burned out at the same time.
Mike
Old Aug 19, 2005 | 08:50 AM
hemertwv's Avatar
Switch replaced, problem solved. Thanks everyone
Extreme Diesel
40
Dec 25, 2006 11:23 PM
Hunter
13
Dec 20, 2002 05:59 AM
kingofdodge7131
Dec 14, 2002 02:43 AM
24
Dec 2, 2002 08:19 AM
