A Question
A Question
Can these trucks start with just one battery?<br><br>Today, the truck wouldn't start...popped the hood and discovered that one terminal on drivers side battery was loose, tightened it up and away she went. it wasn't THAT loose but nevertheless it was loose enough. <br>Would that looseness be enough to not make the truck start? When the key was turned...it was just one click and then nothing. <br>Anyways, she's starting fine now. [undecided]
Re:A Question
You bet they can start off one battery, many members have removed a battery in the warmer climates. However if you make use of your grid heaters on a regular basis then its best to have the two. The reason there are two batteries is due to the huge draw the grid heaters apply when in operation. If it was a loose connection then it would prevent starting due to not having enough juice to turn everything over.
Re:A Question
thats what i thought Kat. Also i have the daytime running lights....so if you DONT have your E-brake depressed, your headlights come on automatically drawing even more juice away from the grid heaters.
Re:A Question
[quote author=goldenears link=board=5;threadid=12181;start=0#115167 date=1047511145]<br>thats what i thought Kat. Also i have the daytime running lights....so if you DONT have your E-brake depressed, your headlights come on automatically drawing even more juice away from the grid heaters.<br>[/quote]<br><br>Thats a Canada only thing on the daytime running lights in case others didn't know.
Re:A Question
[quote author=goldenears link=board=5;threadid=12181;start=0#115109 date=1047505915]<br>It wasn't THAT loose but nevertheless it was loose enough. [undecided]<br>[/quote]<br><br>If it was loose enough not to draw juice, it was probably enough to get some crud started. I'd clean your terminals when you get a chance. You'll probably have to do after awhile anyways.
Re:A Question
Drivers side battery is the primary battery. Passenger side is routed through it, so if a connection is loose (as you said yours was) there wouldn't be enough juice getting to the starter. In other words, you can't disconnect the drivers side battery and run the truck on the pass. batt. without doing some re-wiring.
Re:A Question
The way I understood it, is that we use the passenger battery to crank and then we use the driver side to run everything. All I know is this, is when I hooked up my system to my driver side battery, my headlights dimmed slightly. Hooked it up to the passenger, no more problems with dimming headlights.
Re:A Question
Sure they will start with one battery. Just like starting a ricer with a lawn mower battery. It will work for a while but it won't last when you need more power.<br>Tom
Re:A Question
Mine came from Canada. It even had the kilometer speedo when I tried it out. The running lights REALLY irritate the WAshington State Ferry loaders, at night, they only want parking lights on when you load. So far none have tried to chew on me about them, but I know people that have almost got into fights about it. They are only 50% but still throw a good glare.
Re:A Question
The DRL's are mandatory in canada. At first I really hated them, but after awhile I have come to like them. Oncoming cars are much easier to see in marginal light situations.<br><br>However, depressing the emergency brake one click disables the lights in our trucks. I guess the powers decided that trucks might have to sit while loading, or something.<br><br>When I am in the southern states, I often disable the lights since so many people seem to be annoyed by them.<br>george
mkeanglorldo56
Nov 4, 2007 12:34 PM
Murf
Aug 17, 2007 04:36 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
