Possibly Draging Brakes
Old Nov 22, 2009 | 11:08 AM
Jeff5886's Avatar
When I hit the brakes on my truck, the brake lights stay one for about 3-5 seconds after I release the brake pedal. I am wondering if this is causing my brakes to continue "braking" when I let of the brakes. Anyone ever seen anything like this or know how to fix it?
Thanks
Jeff
2000 Dodge 2500 Sport Cummins 24 Valve, 4x4, Auto, Quad Cab, Short Bed With BHAF, Airdog 100, Edge Juice with Attitude, Pioneer DEH-6100BT, Turbo Silencer Removed, Viper Remote Start, ATS TQ Converter, Upgraded Input Shafts, Shift Kit, Lots More!!!
Old Nov 22, 2009 | 11:18 AM
CarlJensen's Avatar
You might have a caliper hanging up or a bad brake line, if in fact, it is hanging up. It may just be the brake switch. Do you have an IR gun? Checks temp at each wheel. It will show a hanging brake right away.
Old Nov 22, 2009 | 11:20 AM
Jeff5886's Avatar
I can get one, how would I use it?
Old Nov 22, 2009 | 11:25 AM
CarlJensen's Avatar
Run the truck up to speed a couple of times and brake to a stop. A hot wheel indicates a problem. This also works at finding a bad bearing. Aim the heat gun at the center of wheel, not the tire.
Old Nov 22, 2009 | 11:28 AM
CarlJensen's Avatar
Those IR guns are handy. I used one on my fiver to spot heat leaks for winter living in it.
Old Nov 22, 2009 | 07:09 PM
SIXSLUG's Avatar
Sounds to me like your brake light switch may be out of adjustment. I don't think the brake pressure has anything to do with the electrics that trigger the brake lights if you are talking about the taillights and not the brake indicator light on the dash.
Kurt
Old Nov 23, 2009 | 06:17 AM
CarlJensen's Avatar
Sixslug is right. Check the easy stuff first. The switches do go bad, are inexpensive and easy to replace.
Old Nov 23, 2009 | 11:34 AM
01RAMer's Avatar
The only thing that activates the brake lights is the brake light switch down at the brake peddle. New ones has the switch plunger fully seated and after installation, you push a button to make the switch pop out to touch the peddle arm (self adjusting). Make sure you don't have the peddle pushed in at all when you set the switch or it will be out of adjustment.
05 Ram 3500 SRW
May 1, 2011 09:14 PM
Forrest Nearing
61
Mar 31, 2008 12:03 AM
wildcargo
Nov 29, 2005 04:20 AM
Dodgezilla
Oct 12, 2005 04:28 PM
ATEAV8GN
Jan 26, 2003 02:49 PM
