Troubleshooting clock spring
Old Nov 18, 2009 | 09:30 PM
ldornak's Avatar
Is there a method to troubleshoot a clock spring?
I broke mine the last time I replaced my steering box. After installing the new clock spring, the air bag light continues to stay on, but my cruise now works.
I'm thinking I got a defective clock spring, but would like to troubleshoot it if possible.
Old Nov 19, 2009 | 08:24 AM
johnh's Avatar
dealer????????????????????
Old Nov 19, 2009 | 10:03 AM
infidel's Avatar
If something goes wrong with the airbag system such as the clockspring it sets a permanent code.
You need a scanner to erase it even after it's fixed.
Old Nov 19, 2009 | 11:00 AM
ldornak's Avatar
Can someone verify this. Would AutoZone be able to erase the code?
Here's more details of my issue:
I'm on my 3rd clockspring. Long story short, I broke them while swapping through steering boxes. When I broke the 1st clockspring, the air bag light came on and the CC would not work. I replaced that clockspring and everything was great - the air bag light went away and I regained CC. Again, after breaking this clockspring, same symptoms, no CC and air bag light came on. So, when I replaced the 2nd clockspring with the current clockspring, I expected the same results - It would fix CC and turn off the air bag light. It did fix the CC, but the air bag light remains on.
Old Nov 19, 2009 | 11:10 AM
91r/t's Avatar
When I put my new one in the air bag light went off and the sruise started working without the use of any scan tool to delete codes.
Old Nov 19, 2009 | 03:52 PM
ldornak's Avatar
That's been my experience too.
Old Nov 19, 2009 | 10:47 PM
moss765's Avatar
yep same with my truck too
Old Nov 23, 2009 | 11:59 AM
01RAMer's Avatar
If your having that much trouble with different clock springs, I'd be looking at the connectors for a bent pin of faulty connection.
Old Nov 23, 2009 | 03:15 PM
Mike Holmen's Avatar
The Guru
Does your cruise, radio controls, horn still work? I broke mine replacing the steering gearbox as well. Napa sells a clockspring for years up to 2001, not 2002, I had to buy mine from Dodge and was more pricey. It fixed the problem and everything works again. All my steering wheel electronics (radio/cruise) ran thru the clock spring, go figure
94 dodge
May 4, 2007 10:46 PM
vavtx
Jan 7, 2006 06:47 AM
DieselNomad
Jun 15, 2005 07:34 PM
Flake
Jun 1, 2004 04:05 PM
