Outside Temp sensor
Old Mar 20, 2007 | 11:07 AM
mortis_9812v's Avatar
Outside Temp sensor
My temp on the overhead console reads 0 deg. celcius at all times. I was under the impression that a short would read SC and and Unplugged connector somewhere would read OC. So what would cause my gauge to read 0 at all times?
Old Mar 20, 2007 | 03:23 PM
XLR8R's Avatar
Have you checked the connector?
Old Mar 20, 2007 | 06:07 PM
phox_mulder's Avatar
Celsius temperatures can only be recorded in Canda.
Since you're in Idaho, you'll have to change it to Farenheit for it to read anything.
Seriously, the sensor on your truck should be mounted to a radiator support, unsure which side though, start there.
phox
Old Mar 20, 2007 | 11:03 PM
dssimecek's Avatar
Sensor is on passenger side as I recall. Can you switch the overhead to Farenhite?
Old Mar 21, 2007 | 10:32 AM
I cant switch the sensor to Farenheit So i think it might be the sensor. Where can you get these sensors?
Old Mar 21, 2007 | 11:00 AM
smokindog's Avatar
Uh, the dealer would be a pretty safe guess! And I would think the overhead unit itself would be the problem if you can't change from ˚C to ˚F, not the sensor under the hood.
Oh, Just FYI... when the sensor is unplugged it reads -40˚F.
Old Mar 21, 2007 | 09:36 PM
sjester's Avatar
NAPA has them as well for about 13-14 dollars (at least for a 1995). They should also be available in wrecking yards I believe the same sensor was used for a number of Chrysler products. I don't have the part number with me but I believe it was called an ambient air temperature sensor on NAPA online
Steve
ppsi
Oct 13, 2011 07:35 PM
MossyOakCTD
19
Dec 28, 2010 09:11 PM
TNutcher
Aug 6, 2006 11:02 PM
kingofdodge7131
Mar 8, 2006 10:17 PM
turbox2
Feb 6, 2006 07:44 PM
