New Rotors 8800 GVW
Old Jul 27, 2008 | 10:10 AM
GearHd6's Avatar
New Rotors 8800 GVW
I'm in search of some new front brake rotors for my 96 2500 4x4 Ram. I was curious what other people have used for rotors and how they worked out for you. I bought a pair of autopart store rotors a few years back and they were terrible, they warped and then formed rust/scale on the braking surface. So needless to say i'm in search of a "good" pair or rotors. I don't think i'm in need of cross drilled rotors, just a good factory type rotor.
Thanks for any info.
Old Jul 27, 2008 | 10:13 AM
infidel's Avatar
After much success on at least a dozen Rams the only rotors I use are Brembo.
Best price I've found is at www.tirerack.com
Hawk pads from tirerack are a prefect match with the Brembos.
Old Jul 27, 2008 | 10:30 AM
GearHd6's Avatar
Just the plain Brembo's for $73 each? That seems reasonable for a well known name brand. Thanks for the info!
Which Hawk pad would you recommend? I see there is a few different grades.
Old Jul 27, 2008 | 12:30 PM
infidel's Avatar
Yep, just the plain ones. A friend who owns a brakes only shop in Seattle says he can't even get Brembo that cheap and that because of the cost he only uses them on high end sports cars.
I've been using the Super Duty pads but some folks here say they've had good luck with the LTS.
Old Jul 30, 2008 | 11:22 AM
justme-'s Avatar
Agreed- I used brembo's too- from buybrakes.com.
I have used Titanium ti22 pads with no problems, currently loving the Bendix pads with lifetime replacement (1x).
Old Oct 3, 2008 | 07:05 PM
GearHd6's Avatar
I have within the past month or so installed these brake items on my truck and all I can say is, WOW! These brakes have NEVER worked this good before. I'm very impressed. Thanks for the recomendation. It was money and time well spent.
Oh yeah, speaking of time. My wheel studs were so rusted into the unit bearing that I had to cut everyone off and drill them out with a milling machine. I started by putting them in a press, which had a PSI gauge and I cranked some up to 8000 lbs before I just gave up. They weren't even thinking of moving. So the truck got 16 new studs also.
Old Oct 4, 2008 | 11:11 AM
infidel's Avatar
Very first time I've heard of the studs not coming out.
Hope it never happens to me, those suckers are pricey.
Old Oct 9, 2008 | 04:26 PM
GearHd6's Avatar
I guess theres a first for everything, and I was at the raw end of that deal. The studs all cost me about $110 for just the fronts. I NeverSiezed the HECK out of them this time around.
Old Oct 9, 2008 | 09:58 PM
Longbob's Avatar
I checked out the Tirerack and could only find the Brembo brakes for the rear. Are they the same as the fronts? I need to replace the front on my 2000 2500 Quad 4x4. I have upgraded the rear drums with the GM cylinders and that was a huge difference! Now it is time for the fronts.
Old Oct 10, 2008 | 10:59 AM
infidel's Avatar
Sometimes you have to call tire rack, not everything is on their website.
I could be wrong but think the front brakes were the same from '94 to '00
Old Oct 10, 2008 | 07:53 PM
GearHd6's Avatar
They list them for a 99 at $73 each for 8800GVW.
gator_grabber
Dec 18, 2012 09:21 PM
gator_grabber
Jun 26, 2010 03:18 PM
gator_grabber
Jun 12, 2009 11:35 AM
Txwelder
13
Jun 6, 2007 08:50 PM
Munchies
May 16, 2007 07:54 PM
