7500LB GVW or 8800LB gvw brakes?
I thought all 2nd gen calipers/rotors/pads interchanged betweem 2500 and 3500's. minus abs/non abs.....
But why do I keep seeing listings for 7500 lb gvw brake parts vs. 8800lb gvw parts?!
Look on the doorjamb, there should be a sticker there that tells you the GVWR of the truck. There are two setups and I think the difference is a heavier duty axle setup in common with the 3500. I know on mine its 8800lbs
J OOPS
Nov 3, 2009 04:58 PM
