New rims for dually
Old Apr 13, 2012 | 12:24 PM
abchoppers's Avatar
New rims for dually
You guys that have new wheels for your dually did you also change the inner rear wheels too? If i get new wheels I might as well get wider rims, like 8 inches, but than I would think I'd have to get a new inner wheel too. Does anyone sell wider inner rear wheels? Truck is a 97.Thanks
Old Apr 13, 2012 | 01:03 PM
Shovelhead's Avatar
Administrator / Scooter Bum
If you try to go much wider with the rims, you might run into clearance problems both between the rim/tire and the leaf spring, and the clearance between the tires themselves.
Spacers might compensate some, but put a lot of load on the wheel studs.
Old Apr 14, 2012 | 02:57 PM
dodgeguy71's Avatar
I've seen some dually's with wide tires and when I talk to the guys or just looking at them they have spacers to avoid the problems. If you get the same style wheel on the inside dual then you can rotate all of your tires. I've just got 4 of the fancy wheels and 2 plane steel wheels. The steel wheels are rated for more load than the aluminum so it's nice to have them on the back of my pig.
Old Apr 17, 2012 | 05:58 PM
abchoppers's Avatar
Thanks for the reply guys, I appreciate it.
Diesel Dave2
Jan 23, 2013 04:46 PM
JMOS4
Feb 1, 2012 07:59 PM
Mark Hodowanec
15
Nov 11, 2004 08:50 AM
GO 4LO
Dec 31, 2002 02:37 PM
