More lighting problems
Old Oct 16, 2006 | 10:44 PM
mulepackin's Avatar
Question More lighting problems
My headlights go out alltogether when I change from low to high beams. Operating the control seems to get them back on after a few paniced pulls. Usually happens when towing, but has happened when not pulling. I believed the tow package on this truck was supposed to include relays to prevent this common problem. Not sure. My dad had sim prob. with 96, changed mult func switch, didn't help. Changed light switch, put in heavier direct ground. That helped. Where should I start? Multifunction switch? Light switch? Summit relay kit? Brite Box? Anything else?
Old Oct 16, 2006 | 10:51 PM
phox_mulder's Avatar
Common problem in Dodge vehicles.
phox
Old Oct 17, 2006 | 01:05 PM
Jerrod's Avatar
Where is the multifunction switch? and is it hard to swap
Old Oct 17, 2006 | 04:25 PM
hemertwv's Avatar
It is the high/low beam lever on the column, last one I bought was I think around 40 bucks, 3 or 4 torque screws to take the cover off, and 2 or 3 to take the switch off and some wire connector plugs and you are done.
Dealer supplied part.
Old Oct 17, 2006 | 04:29 PM
super62nova's Avatar
I had the same problem, It was the switch itself. I bought one at Carquest yesterday, 25.00 dollars. Solved the problem.
Old Oct 31, 2006 | 05:46 PM
mulepackin's Avatar
Lighting Problem
Replaced the multifunction switch. This has so far fixed the problem. Time will tell.
DJ Turbo.
Oct 13, 2011 09:11 PM
Alan88
Aug 8, 2010 09:09 PM
90firstgen
Apr 25, 2008 07:59 PM
Zotie
13
Jan 28, 2008 11:55 AM
luckydiamondran
Mar 8, 2005 02:17 PM
