Lighting Problems
Old Jan 25, 2008 | 12:09 AM
Zotie's Avatar
Lightbulb Lighting Problems
So I noticed that one of my headlights is dimmer than the other, like by a lot it barely puts out any light on high and low. The other "normal" light doesn't put out much light either but appears bright if you look at it. Driving at night basically sucks its really hard to see anything, like I have no lights. I replace both bulbs and nothing? It hasn't been a gradual thing its been this way since I bought it (used) i just don't do much night driving. Anyone have any suggestions? Also I notice that when I'm in the truck and its idling the lights in the cab periodically get bright then return to normal. If anyone could help me with either of those two problems it would be much appreciate
Thank You.
Old Jan 25, 2008 | 12:21 AM
mopar-or-no-car's Avatar
The fact that they get brighter and dimmer is probably your grid heater turning on and off as it uses alot of power. You say one light is brighter then the other, Could it be that they are poorly aimed. If there aimed good you could pull the bulb on one side and check it with a voltmeter and then do the same to the other side to see if they are the same. The factory headlights suck on these trucks. My best suggestion would be to either buy some one piece headlights with clear lenses like these http://cgi.ebay.com/ebaymotors/94-01...spagenameZWDVW and upgrade the wiring with a hd harness from lmc truck or elsewhere. Or put sport lights on like these http://cgi.ebay.com/ebaymotors/94-01...spagenameZWDVW these use four bulbs, two for low beam and four on high, they also have clear lenses and requiring doing some wiring but no cutting factory wires though.
check out danielsternlighting.com RIK-RAM kit to properly install improved Dodge Ram Sport
9004/9007 headlamps in place of standard
1994-2001 Dodge Ram 9004 headlamps: $79
or
suvlights.com http://www.suvlights.com/product_inf...roducts_id=116
Old Jan 25, 2008 | 10:33 AM
nv_brewer's Avatar
A word of warning. I bought these last month and found they have no method of aiming. They are fixed position. I can't seen squat right now. I'm thinking of tilting with spacers behind the mounting screws.
Old Jan 25, 2008 | 12:07 PM
Really? How dumb are some companys to build headlights without adjustment? I did the sport headlights on my truck and I love them.
Old Jan 25, 2008 | 12:10 PM
Zotie's Avatar
I actually pulled the light out and checked it out of the house while it was on, and it was dim. I switch the same light to the other side and it was bright. I didn't have a voltmeter handy, but from what it sounds like this is a notorious problem, bad factor wiring and lenses?
Old Jan 25, 2008 | 03:16 PM
Hey I was reading another thread haloman has those lights and said there is an adjusting screw on the back? Dumb place for it. But my vote still goes towords the sport lights. Do a search on here about them.
Old Jan 26, 2008 | 12:11 AM
nv_brewer's Avatar
I stand corrected. After pulling my light tonight it sure nough has an adjustment. When I first installed it I thought it was for a ground wire I didn't find.
I also discovered that I only have 11.5v at the light. I'm buying the harness upgrade tonight.
Old Jan 27, 2008 | 07:58 PM
psd tuner's Avatar
had the same problem but mine was the fuse. i dont know how the h*** did that thing work with a popped fuse.
Old Jan 27, 2008 | 08:00 PM
psd tuner's Avatar
had the same problem but mine was the fuse. i dont know how the h*** did that thing work with a popped fuse. i was even getting 12v to my bulb, both of the filiments was on @ the same time though.
Old Jan 28, 2008 | 08:27 AM
haloman's Avatar
Yep they have an adjustment screw.
Zotie I would just get the relay harness from lmctruck.com and have it activated by the headlight socket that is working.
Old Jan 28, 2008 | 11:01 AM
nv_brewer's Avatar
Finished building my own relay harness this weekend (I have a hard time waiting for UPS ). Cost about $30 with Napa parts (2 relays, wire, spade connectors, wire loom) . Works great and I now can see where I'm going .
Old Jan 28, 2008 | 11:46 AM
haloman's Avatar
LMC harness only cost $30 plus shipping. I guess my time is too valuable to make one.
Old Jan 28, 2008 | 11:53 AM
nv_brewer's Avatar
Relays: $8.95 Wire: $4.95, Lugs: $2.95
Relaxation while doing what I enjoy: PRICELESS.
I guess my time is pretty valuable too.
Old Jan 28, 2008 | 11:55 AM
haloman's Avatar
I was only joking (thats hard to convey on the internet), knowing how well I solder I would blow something up for sure.
DJ Turbo.
Oct 13, 2011 09:11 PM
Alan88
Aug 8, 2010 09:09 PM
90firstgen
Apr 25, 2008 07:59 PM
mulepackin
Oct 31, 2006 05:46 PM
luckydiamondran
Mar 8, 2005 02:17 PM
