Lower ball joint- 2wd ???
Old Sep 1, 2008 | 01:18 PM
powersmoke's Avatar
The lower ball joints are spot welded on.
Will I be able to get away with just press fitting the new ones in or will I have to spot weld them once they are in place?
Old Sep 1, 2008 | 01:29 PM
Jason Foster's Avatar
I've never heard of the ball joints being welded on. They should just be a pressure fit. In which case you shouldn't have a problem pressing them in place, providing you don't damage the housing removing the old ones. I have never owned a 94 2wd so without seeing what you are working with I'm not sure of an exact solution.
Old Sep 1, 2008 | 08:51 PM
dozer12216's Avatar
Yes, I'm sure some joints were welded on, either by manufacturer or after the fact in repair attempt. Carefully rewelding with wet rag and very short welds should cause no problem.
Old Sep 2, 2008 | 12:36 AM
powersmoke's Avatar
It was just tacked on 2 spots.
Probably why NAPA also sells the lower ball joints with the lower control arm.
Not worth the extra cost and work.
redramnc
Sep 1, 2008 02:46 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
96grndodge
Mar 11, 2007 02:24 PM
Diesel diehard
Feb 23, 2004 05:05 PM
stoneman
Feb 10, 2004 05:54 AM
