Low speed Rocking
Old Oct 12, 2013 | 10:29 PM
Ironduke10's Avatar
Low speed Rocking
When driving at 25-45 the truck, it has a noticeable rock seemingly from left front to right rear. Almost as if the right rear shock is gone. The right rear lists very slightly from left to right too.
Old Oct 14, 2013 | 03:35 PM
joem's Avatar
last year mine did that too, a friend thought I had a broken leaf. turned out to be old sticky shocks combined with the weight of a full tank of fuel making it sag towards the drivers side. Replaced the shocks and when nearly empty the truck looks and rides perfect
Old Oct 14, 2013 | 10:10 PM
Ironduke10's Avatar
The shock on the right rear may be the issue. Thanks
Old Oct 15, 2013 | 09:18 AM
Numidian's Avatar
Make sure your tires aren't cupped. I had an F150 that felt like it was going over rumble strips at 5mph, then it would even out with speed. The cause was cupped tires.
Old Oct 15, 2013 | 11:14 AM
SIXSLUG's Avatar
Shocks don't support weight, they dampen the spring's rebound....
Sounds like broken/tired springs, check the leaf pack for missing or broken spring pieces, also, the front cols will tire over time.
Old Oct 16, 2013 | 10:20 PM
Ironduke10's Avatar
OK. Appreciate the reply.
Old Oct 16, 2013 | 10:23 PM
Ironduke10's Avatar
Very plausible. I do haul a Lance Camper on a fairly regular basis over rough dirt trails. I do have air bags as well.
Old Oct 21, 2013 | 08:59 PM
KATOOM's Avatar
If the feeling you're experiencing is like the tires are egg shaped then its not uncommon. Typically the speed its felt is around 45 mph. People have chased their problem by replacing tires, shocks, mounts, wheels, etc..... I had the same problem and found it was separated rear tires. I think these trucks are far more receptive to tire condition and shape than people give credit.
Old Oct 21, 2013 | 10:20 PM
SIXSLUG's Avatar
I was also thinking maybe a tire issue....
This would make sense.
Old Oct 22, 2013 | 07:48 AM
patdaly's Avatar
Yep, slipped belt would be my first guess.
PADuallyBoy
Jan 3, 2009 02:32 PM
Treangen
Apr 9, 2007 03:12 PM
mhuppertz
Sep 26, 2005 03:57 PM
